Old 04-04-2011, 05:44 PM
dwc1435 dwc1435 is offline
intermittent ps problem
can you guys give me and idea of what the symptoms of a bad pump and a bad rack. 10% of the time the steering goes a little hard turning to the left. then most of the time it goes easy. its only when both TIRES are on the ground it turns hard to the left. even if i jack it u and put all the pressure on the drivers side that turns hard it doesnt do it AT ALL. the back of my pump is all wet. no leaks under the car. Please symptoms of both would help.
P.S. it seems to be worse when system gets hotter.
2000 Grand Prix SE
140,000 miles
3.1 motor.
Old 04-07-2011, 06:59 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: intermittent ps problem
Best to see where the leak is coming from. The power steering pump would be a good starting point. However, it sounds like you have the early signs of a rack and pinion going bad. Main symptom is the hard to the left feel.
Timeslip 08/12/06
AF Community Guidelines
Old 04-07-2011, 08:42 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Bob. The hard to the left feel is indicative of a rack going bad. It has to do with the input shaft bearings (where the steering column attaches).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-07-2011, 10:54 AM
hey thanks for the reply 2 more things to add, when i turn to the right, it is not exactly easy, it gives me resitance also not like the other side though, it just wants to go back to middle. The back of my pump where the steel line meets the rubber hose on top looks like its sweating a bit. thanks for any more help.
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
'91 Caravan has intermittent problem with low engine power jerbes Caravan | Voyager 2 09-20-2004 10:56 AM
90 jetta gli intermittent problem kaloko '83 - '90 4 08-29-2004 09:26 PM
90 Jetta intermittent problem kaloko '83 - '90 0 08-27-2004 10:17 PM
Intermittent problem with starting car jakeblake Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 03-07-2002 08:12 AM
