Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-04-2011, 04:08 PM
Gm crazzy Gm crazzy is offline
Send a message via Yahoo to Gm crazzy
few 1970 olds 98 issues
1. when you first give the car a little gas it wants to stall but if i just put the pedel to the floor it does fine also i have no issues with it wanting to stall while driving only when i start to accellerate..
2. ever since i bought the car when ever you turn the headlights on or the dome lights are on they just flicker..i wasnt to worried about it at first but its just getting worse and worse..ive changed the alt. and put an optama yellow top in it, so i was wondering if it may toped working be the voltage regutator?
3. also my gas gauge has stoped working and only moves between full and 3/4 of a tank..sending unit?
Old 04-04-2011, 07:32 PM
maxwedge maxwedge is offline
A990 racer
Re: few 1970 olds 98 issues
Number one is usually a carb issue assuming no vacuum leaks, high test fuel, proper tune up specs. 2 could be the regulator, a voltmeter should be used to check alt output, 3 disconnect the gae wire at the tank look at the gage, then ground that wire, if the gage reads full then empty the dash gage is good. You should have a shop manual if you want to be able to properly work on this.
The Following User Says Thank You to maxwedge For This Useful Post:
Gm crazzy (04-05-2011)
Old 04-05-2011, 08:03 PM
thanks for the help, i got 1 and 2 fixed..it ended up being a bad voltage regulator and what looked like a fuel filter from 1970 and some old gas..still working on number3
1970 Olds 442 BIGDADDY78 Oldsmobile Classics 2 11-05-2009 11:56 AM
1970 olds cutlass supreme hoilday coupe 4-door drwolfenstein Cars/Parts for Sale/Exchange 6 09-07-2006 03:32 PM
My 1970 olds 442 post coupe ^_^ Sasquatch426 Engineering/ Technical 2 02-23-2005 06:17 PM
1970 Olds Cutlass S molding denalio34ceo Cutlass Series 1 08-24-2004 04:20 PM
1/4 mile time for 1970 olds ninety eight? BLAH98 Ninety Eight 1 03-11-2003 11:40 AM
