Old 04-03-2011, 10:31 AM
bigmanjake bigmanjake is offline
Exclamation 99 blazer STUCK IN 4LO
99 blazer lt, has auto4wd 2hi 4hi 4lo button on the dash.
What happen was... I drove down the street in 2hi, everything normal, I stopped to test the 4wd put it in 4hi, drove down the street, everything normal, I stopped put it in nutrel put it in 4lo, drove down the street, everything normal. Went to take it out of 4lo and its stuck.
I've tried letting it roll and switching. I disconnected the battery . I tried running it threw the gears and switching to knock it loose. I replaced the vacuum actuator under the battery tray.
When I start the truck all the lights come on, on the 4wd buttons for a sec then the 4lo blinks 3-5 times then stays solid. When I hit the 4hi or 2hi (in Nuertal} I hear clicking near the tccm area, I hear the front axel accuator and I hear somthing near the tcase, all while the light 4hi or 2hi light blink but after a few seconds the noices stop it continues in 4lo.
Service 4wd light in not on.
Any ideas what's wrong?
Old 04-03-2011, 03:02 PM
viggy58 viggy58 is offline
Re: 99 blazer STUCK IN 4LO
check the electrical connections. i don't know much about 4 wheel, but i seem to recall some people having some corroded connectors, that once cleaned, fixed the problem.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 04-03-2011, 04:21 PM
old_master's Avatar
Advisor/Moderator
When the 4WD lights blink, they are displaying a trouble code. Watch closely, how many times do they blink?
You have to know how it works,
to figure out why it doesn't.
2002 Blazer Stalls, Key Stuck, Won't start MarkSpeed6 Problem Diagnosis 5 08-30-2010 02:14 PM
02 avalanche stuck in 4LO tjmjr72 Avalanche 1 05-24-2009 08:30 AM
95 blazer stuck in 4lo and keep blow 4wd fuse matthew81 Problem Diagnosis 16 03-02-2009 09:09 AM
98 blazer stuck between 4hi & 4lo loudjason Problem Diagnosis 13 01-16-2009 04:11 PM
93 S10 Blazer 4hi-4lo scopeface Problem Diagnosis 8 12-01-2006 08:55 PM
