Old 04-03-2011, 12:12 AM
FosgateGuy FosgateGuy is offline
Differences in Fuel Pumps?
I've been looking for a fuel pump for my 2000 silverado 1500. I ordered one from ebay but it only had one connector on the top of it and the factory had 2 connectors which are both different styles than the one on the new pump. The company says I'm suppose to just cut my factory wiring and hard wire the new pump? I've looked into buying the pump from auto parts stores but they are between 260-300 bucks and I'd really like to use a cheaper alternative. So I was wondering if this is normal to have to re-wire my harness to fit a pump, also what will I be losing by not having the other connector hooked up? Any advice will be greatly appreciated, I'm stumped! Thanks
Old 04-03-2011, 07:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Differences in Fuel Pumps?
What engine?
Your best bet is to get a Delphi oem type pump.
Airtex and aftermarket stuff are junk.
Even with a OEM type Delphi some have tom be rewired but the pump comes with the wiring harness if needed.
MT
Old 04-03-2011, 08:11 AM
MT-2500's Avatar
AF - Advisor
The one plug pump does not have the EVPA emmisions sensor pressure sensor.
If your truck has the 2 plug pump OEM setup you will need a 2 plug pump.
The rewire kit/plugin is only for the fuel pump and fuel level sending unit.
No way a one plug pump module will work in place of a 2 plug module.
MT
Old 04-03-2011, 09:04 PM
j cAT j cAT is offline
if you have the non evap emissions fuel pump this would mean installing would cause the engine light to come on and you would not pass state emission test..they make two types ..you should have the TCF type 2 connectors...
If your getting rid of this vehicle cheap pump will save YOU some money..If you keep this vehicle NOT !
delphi fuel pump FG0271 should be the correct long life pump...about 250.oo..............
Old 04-04-2011, 07:25 AM
slo99sierra slo99sierra is offline
I've forgotten what model exactly but I've heard many people say they got the Walboro fuel pump at half the prices of a OEM fuel pump. From what they say the Walboro pumps are just as good as OEM. And yes, you have to make sure you know what you need before ordering one! Most, if not all 99+ trucks have a 2 plug fuel pump.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work.
Old 04-04-2011, 08:34 AM
the walboro fuel pumps have a 90day warrantee or 4,ooomiles ...
not good .
Old 04-05-2011, 10:57 PM
ColoradoSilverado ColoradoSilverado is offline
not good .
Delphi pump is over $300, comes with a 12 months warranty and breaks after 13 months... Got a aftermarket off of Ebay for $50, lasted a lot longer then the Delphi so far...
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 04-06-2011, 05:10 AM
muff34 muff34 is offline
Gee I wonder WTF is up with my Delphi pump. 3 years later and it`s still working like a champ
Life Is A Highway ,Enjoy The Ride
Old 04-06-2011, 06:58 AM
I must have gotten a monday morning pump or something, didn't want to fork over another $300 that's all.
My Truck:
My wife's Truck:
Old 06-24-2011, 10:39 PM
sa200 sa200 is offline
Ive been waiting for my $45 Carter pump to quit for 6yrs now.
Old 06-25-2011, 08:10 AM
what year and vehicle is this carter pump used in ?
Old 06-25-2011, 04:53 PM
1994 5.7 blazer, got it at napa.
Old 06-25-2011, 08:08 PM
that makes a difference in the cost. a carter fuel pump for a 2000 silverado 5.3L engine costs about 250.oo... delphi pump costs about 265.oo...the difference is the delphi is a direct fit with no connector fabrication ....... most find this to be the best for a trouble free install and no emisson dtc issues...
carter does make good pumps but with this model vehicle you must mess with the OEM connector for install..........
Old 06-26-2011, 08:10 AM
j cAT, what do you mean by " and no emisson dtc issues..." ?
Bert
My Truck:
My wife's Truck:
Old 06-26-2011, 08:26 AM
Bert
if the carter fuel pump is not properly cut into the OEM wiring then the emissions dtc can come on ..
these vehicles have two fuel pumps used. one is the emissions pump, the other is no emissions so if you have the emissions type which most do in the US ,,,,you may find problems with the wiring of it ,,,if you are not up on how to properly wire it to the vehicles wiring.
for the cost diff why screw around ..?
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 11:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 03:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
