Old 04-02-2011, 03:31 PM
schri00 schri00 is offline
Preventing Fuel Vapor Lock
Hi, Does any one know what is the best way to prevent fuel vapor lock? This is not a model specific question. I'm wondering how to go about preventing this kind of problem.
Are there some thinks I should look for when dealing with this problems? like fuel lines too close to hot engine parts, etc. and if there are some recommended after market accessories I can use like heat shields for carburetor, fuel lines, etc.
Thanks.
Old 04-02-2011, 04:08 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Preventing Fuel Vapor Lock
One method may be to use a high pressure electric fuel pump and fuel injection. Also, running the fuel lines away from exhaust and not directly over valve covers, etc. will help.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
schri00 (04-02-2011)
Old 04-02-2011, 05:22 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Originally Posted by schri00 View Post
Hi, Are there some thinks I should look for when dealing with this problems? like fuel lines too close to hot engine parts, etc. and if there are some recommended after market accessories I can use like heat shields for carburetor, fuel lines, etc.
That's half of it.
The lower the pressure of the fuel, the lower the temperature it will boil.
Install an electric fuel pump as close to the tank as possible. This minimizes the amount of fuel in the line that is actually under a vacuum, or at the suction side of the pump, if you will. If you can get a pump suitable for your carb INSIDE the tank that would be best. But that probably can't be done....
The Following User Says Thank You to Black Lotus For This Useful Post:
Old 04-02-2011, 05:27 PM
brcidd's Avatar
brcidd brcidd is offline
Push the fuel, instead of sucking it.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Old 04-02-2011, 06:07 PM
Thanks for all the ideas.
How do you prevent Vapor Lock Bobandbadger S-10 2 07-18-2009 04:50 PM
New steel fuel rail-vapor lock Greenmachine1995 Aurora 9 02-17-2005 05:48 AM
Tags
fuel , lock , system , vapor
