Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 04-02-2011, 10:34 AM
jestersht's Avatar
jestersht jestersht is offline
99 durango battery drain
i just got a 99 durango and every morning i have to boost it in hot or cold weather but it starts fine all day so i replaced the battery and still doing it, plus when i boost it the durango dosent start right away it starts then stalls like its not getting fuel so i replaced the fuel filter and still the same thing, i cant see any lights on or anything running when truck is off.
any ideas on why it keeps draining every night would help greatly i love the durango and would hate to get rid of it, it has the 5.2l v8 318ci
Old 04-08-2011, 10:41 AM
N8ECH N8ECH is offline
Re: 99 durango battery drain
Jester:
How many miles on your D, and when was last time it was tuned up?
The symptoms you describe are indicative of a bad battery, but since you have replaced that, you should be good to go there.
IIRC, the fuel filter is inside the fuel tank. Did you drop the tank to replace the filter? If so, I would have replaced the fuel pump also. Could be an aging pump as well.
Don
Flame Red 2004 Hemi Durango SLT 4x4
w 3.55 gears.
Old 04-08-2011, 11:44 AM
inafogg inafogg is offline
with the vehicle off,remove negative battery cable.set volt meter on dc volt
setting,neg lead to neg battery post & positive lead to negative cable.this will
show if there is a drawl in the system.make sure there is no light on hood
if so remove the bulb & all doors are closed.if you see a drawl start removing fuses 1 at a time,until drawl drops, about 1 v is normal.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-27-2011, 07:45 PM
jestersht's Avatar
fixed the issue it was the rear wiper motor
Old 04-27-2011, 10:16 PM
good to hear,thanks for the fix
Live For Today
Yesterday is gone,
Old 05-24-2011, 02:03 PM
xFatcatx xFatcatx is offline
could you please elaborate? I have had a battery draining (very very slowly) issue since I have had my 99 durango for 2 years now. I put a new battery in and i can already feel that one slowly dying. would really appreciate knowing exactly what you did. thanks
Old 05-24-2011, 02:19 PM
danielsatur danielsatur is offline
Also see Similar Threads on battery drain @ bottom of your thread.
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 12:37 AM
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 04:18 PM
Battery draining rocketwild Lumina 2 06-30-2009 03:47 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
