Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Astra/Astra Coupe/Kadett
Old 04-01-2011, 01:47 PM
marko18 marko18 is offline
Thumbs down indcator fault.
hello there, has anyone had this problem before!!!!!
I got a astra sxi 04 plate 5 door. every time you lock the doors by remote the indcators should flash once, but tryed it tonight and find that only the right hand side flashs, So the left hand side is inop. All the doors lock and unlock ok. I really need some help fixing this fault. let me know asap
cheers
Old 09-03-2011, 04:29 AM
Post Re: indcator fault.
found the fault to be the indicator flash unit which is under the drivers side dash with the fusebox, its the big yellow box like a relay.
electrical fault/ground fault/fuel starvation tom black Blazer 2 10-14-2003 02:12 PM
Is O2 Sensor Fault Code 100% Correct? BETTER THAN A WRX Maintenance 12 06-10-2002 05:25 AM
Peake Industries Reset and engine fault reader RogerUK 3 Series 1 04-29-2002 10:41 PM
bluebird engine fault code wanted zefire Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 02-11-2002 02:33 PM
318i central locking fault icehoose 3 Series 2 12-18-2001 03:37 PM
