Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 03-31-2011, 06:37 PM
Automobilefanatic Automobilefanatic is offline
2000 Protege check engine light + screeching/scratching noise during acceleration
Mazda Protege 2000 here with 230k km on it.
For the past year during acceleration but only when I press the pedal down to a certain point (if the pedal is pressed any less or more there is no noise)
around cruising speed of 40 miles/hr on a flat road when the pedal is pressed at that point it will make a loud screeching/scratching sound.
The check engine light appeared around 3 days ago, does this have anything to do with the noise as well?
The noise is not belt related as that was a separate noise problem I had earlier but was fixed.
Old 04-01-2011, 06:19 PM
adamgrant adamgrant is offline
Re: 2000 Protege check engine light + screeching/scratching noise during acceleration
It sounds like a slipping belt? Do you know the what code is set with the check engine light?
Old 04-04-2011, 01:18 AM
It is not belt related, I stated that in the original post, I know what a loose belt sounds like because I had that problem before but it was fixed.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
