Old 03-31-2011, 02:04 PM
Mobiletec Mobiletec is offline
Smile 1997 safari flickering headlights
Hi everyone. Iave got a 1997 GMC safri that has flickering lights on the dash Headlights just about anything thats lit. Alternater test shows charging ok. Any suggestions as to what this problem may be. regards
Old 04-13-2011, 01:14 PM
drew300 drew300 is offline
Re: 1997 safari flickering headlights
My Saturn did a similar thing. The battery negative cable was loose. When tightened, the fault went away. Odd that it started fine.
Old 06-25-2011, 08:12 AM
MikeS144 MikeS144 is offline
My 94 safari did the same several years ago. Turns out the blocking diode was going bad. They don't recommend replacing the diode in these alternators so I just swapped it out. Spring for the new lifetime warranty unit. Save you the trouble of doing it again in 6 months.
94 Safari 203000 miles
94 metro 310000 miles
HID Headlight Flickering Blink Flash poppeman 9-7x 2 07-24-2012 10:32 AM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 05:03 PM
1997 safari headlight plug melted Mobiletec M Bodies 1 09-13-2009 07:59 AM
Headlamps / DRL flickering umfindi Malibu 2 03-29-2009 02:08 PM
flickering headlights P11GT General 19 09-29-2001 07:58 PM
