Go Back   Automotive Forums Car Chat > Mazda > Millenia/Xedos 9
Old 03-30-2011, 01:19 PM
Oprava Oprava is offline
Millenia S 1999 P0431 code
Over the last 14 days once in a while when I stopped the car I could smell something like burnt oil while still in a car. When I opened a hood I do not see any smoke or could find an oil leak visually or by smelling. I have not noticed any excessive use of oil. Today P0431 code sprang out. Is the pre-cat about done or is it something else masquerading as a pre-cat problem? Thanks.
Old 04-01-2011, 07:28 PM
adamgrant adamgrant is offline
Re: Millenia S 1999 P0431 code
Sometimes the valve cover gaskets will leak around the the spark plug area and let oil in there, giving an oil smell and also causing a misfire which could damage the converters. The precats are built into the maniflods on millenia's. They give a rooten egg smell off if theres too much raw fuel entering them..... was there any other codes?
Old 04-04-2011, 08:36 AM
Thanks for the response. There were no other codes. I cleared the code 4 days ago and it did not come back. There was never a smell of rotten eggs. The smell of burned oil appears irregularly. For the last 4 days no smell at all. I will check leakage of oil around the cover.
Problems with my 1999 Mazda Millenia V6 2.5L IcyBob Millenia/Xedos 9 0 01-04-2010 07:04 PM
1999 - P0301 Code. Michael P. Windstar 5 10-29-2004 10:15 AM
1999 GMC code P0302 jdod85 Sierra 1 10-28-2004 09:36 AM
1999 prism code P0441 purge flow rate johnholl General Discussion 0 07-15-2004 12:28 PM
1999 blazer Code P0446 davydawg Blazer 7 06-10-2004 02:01 PM
