Old 03-30-2011, 12:10 AM
hot_sd hot_sd is offline
Troubleshooting lead/pull issue
I wonder if anyone can help me with some suggestions on trouble shooting this. Vehicle is a 2000 Metro 1.3L. The problem has been around for a few years but I don't drive the car much and so never really got around to figuring this out. I'm in the process of fixing a bunch of small issues and just got around to this.
Anyway this started a few months after an adventure on an unpaved sand filled road in the high desert thanks to my GPS. The vehicle pulls to the right. If I shift into neutral and take my hands off the wheel it quite rapidly pulls to the right. So I have discounted torque streer.
I've jacked up the car and inspected all the suspension components - nothing looks obviously bent or damaged. I tried swapping the front tires between the left and right - still same result. Engine mounts look okay although I cannot really see the whole thing.
I just took the car in for an alignment check and everything is within spec.
I also looked for play in the streering rack and wheel bearings but again nothing seems to be loose.
I'm not sure what to check next. My suspicion is that something is bent but I cannot figure out how to spot it. Any tips on what to look for?
Old 03-30-2011, 04:39 AM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
Re: Troubleshooting lead/pull issue
Has the alignment of the rear tires been checked? Did you swap them as well? The rear alignment can make the car pull as well. Are all the tires the same and are they inflated to the same pressure?
MMM
Old 03-30-2011, 10:29 AM
MMM
Yes the alignment check was for all 4 wheels. The rear left tire shows an out of spec toe at -0.1 deg. The toe on the right rear is +0.11 deg so the alignment rack shows the total toe as 0 and th thrust angle as -0.11 deg.
I was assuming if this was the problem it would pull to the left since the neg toe is on the left. But it pulls to the right. The readout also shows the thrust angle in green so I assume the measuring computer thought there was no issue.
I have not tried swapping the rear tires. That's a good point - I will do that and see if it makes a difference.
As far as I know all the tires are inflated to the same pressure (32 psi cold).
Old 03-30-2011, 11:43 AM
Scrapper Scrapper is offline
AF Premium User
even if tires look good there still can be a belt broke or it came out of round neither of thse are your falt. i wold switch right to left see if it pulls the other way and sometimes it will not pull at all. so if it pulls other way you have a bad tire. i was alignment man for about 18 years and i know they can change that print out so i'd have it checked again some where else but if you do what i told you on tires and quits pulling or pulling the other way i don't think he changed print out. i would not do this to people it gives us alignment men a bad name. on more thing i wouldn't had toe set at zero i would go to 1/16th. in atleast.
Old 03-30-2011, 11:56 AM
Thanks for that - I was not aware that they can change the printout although I was suspicious. Probably a good idea to have it checked somewhere else. The place I took it to was offering a free check and then I think it was $80 to have the alignment done. However, the store manager was busy so I spoke with the assistant manager who was not happy when I told him I wanted to see the printout before I authorized any repair - I guess he wanted to fix something regardless of whether the alignment was good or not. I got annoyed and then spoke to the shop manager who oversaw the rest of the test.
Just reminded me why I usually do all the repairs on my cars myself.
I have one of those cheap alignment tools with a sliding gauge - it only checks toe. Not sure how accurate they are but using that I could not find any toe problem.
Old 03-30-2011, 12:25 PM
AF Premium User
thats what i would do on alignment another thing you can go watch them even if it sais employees only you just got to stand back away's or there hiding something if they tell you no you cant say drop it and ge it out. it's not all because of ins. i always ask if they wanted there old parts back if they said no i threw it in the iron barrel. for beer ofcourse when we had enough to buy with.
good luck........
Old 03-31-2011, 08:54 AM
brivers brivers is offline
Might want to check for brake drag on the right side, front and back.
Old 03-31-2011, 10:53 AM
AF Premium User
i doubt a rear will will make it pull it might lockup on rear and that wont make it pull either.
Old 04-01-2011, 02:28 AM
Brakes are fine as I just finished doing a full brake service. I had not checked the pads in a long time and for some reason the warning strip did not contact the rotor on the driver side to warn me so the first I knew I needed new pads was the sound on pad metal on the rotor. Needless to say I also had to replace the driver side rotor as there was scoring due to this although I stopped driving the car soon after I started hearing the noise.
So then I took some time to service the system. New pads, new rotor on the driver side, caliper pins greased with new grease, removed the rear drums and cleaned everything out and also inspected the shoes. Then replaced the fluid with new fluid - the old fluid was looking quite dirty and was several years old. In the process ended up rounding the nut on one of the bleed screws so had to get a new one and replace.
But at no time did I find any dragging brakes. I've yet to try swapping the rear tires - will do that this weekend.
Old 04-01-2011, 08:51 AM
May want to look at the lower control arm bushings, At rest it all may appear fine. Try using a pry bar to see if they're worn. You can also put it in park or 1st gear with engine and parking brake off and rock the car back and forth to see any play. If you have power steering you may also try jacking the front end up, starting the motor and see if the wheels turn to the right by them selves. If that happens you probably have a problem in your rack, like a bit of dirt.
Old 04-01-2011, 11:18 AM
Thanks that's a good tip - I will try that. I did try pushing everything by hand but I was unclear if that would develop enough force to be able cause any movement. Nothing moves when simply checking by hand.
Old 04-02-2011, 03:21 AM
Tried swapping the rear tires with no success - still pulls to the right. Also looked under the car and moved it back and forth as suggested but again I could not see anything moving or twisting. I did see the torque rod moving as I got to the point when the park lock engaged so I assumed that is normal.
At the moment the only idea I have is to get another alignment check.
Old 04-02-2011, 04:57 PM
AF Premium User
sounds like to me pinched line or front rubber hoses they colapse inside and wont let piston go back in.
Old 04-02-2011, 08:09 PM
inafogg inafogg is offline
hot sd,did you check the height of all 4 wheels??
maybe take a few measurements control arm to a
font/rear point & checkl it against the other side
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 04-02-2011, 11:45 PM
Were you referring to the brakes? I did not see any obvious problems with the brakes when I serviced the system a couple of weeks ago.
Does my 1973 MGB require LEAD or NO-LEAD? hooverbean MGB 1 06-19-2010 06:45 AM
re-attach defog lead? zoniguana Taurus | Taurus Wagon 4 10-16-2009 07:58 AM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 08:32 PM
1994 safari brake pulling problem kcs213 M Bodies 4 03-24-2009 11:00 PM
trunk pull down closer ksflatfoot General Discussion 0 03-20-2009 09:43 AM
