Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-29-2011, 03:38 PM
bandaidmd bandaidmd is offline
coolant temp
my 96 5.7 seems to run a bit cool ,according to the scan gauge it runs around 170 to 173 on a 50f day and the dash gauge seems to agree (for what its worth with only a number at the start and end) . Temp sensor out of whack or is it really running that cool? it comes up to that temp normally so it seems that the thermostat is working.
whats the procedure to check it
Old 03-29-2011, 04:14 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Re: coolant temp
Not exactly sure what your concerned about. Seems like your truck is running fine. Typical gauge runs max 260 degrees, you're in the median range. If while operating the vehicle the gauge is fluctuating, then I would think you should be concerned.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 03-29-2011, 06:09 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: coolant temp
The thermostat is the most likely culprit. These cooling systems are very efficient and if the thermostat is stuck open a little, the engine will warm up, but not reach operating temperature. It is much more common than the sensor malfunctioning. Based on the price ($5-$7) and the ease of the repair, it is generally advisable to just replace the thermostat if you suspect they are bad.
The normal operating temperature is 195. Running below that causes the engine to run less efficiently. The OP's temperature is also very close to the temp at which the engine enters closed loop. Any cooler and it may stay in open loop, which would cause more fuel consumption.
Another concern is that running any engine below 180 degrees doesn't allow the oil to get warm enough to boil out condensation. This along with the less efficient operation can more than double normal engine wear.
Old 03-29-2011, 07:09 PM
j cAT j cAT is offline
Re: coolant temp
you should be running at 195deg F range. not 170 deg F ...
thermostats made today are not very good...
get a pot of water and heat to 212deg F boiling . using a temp gauge measure temp of water at 212 , themostat should fully open ..stop heating the pot. as the temp drops measure at what temp the themosat closes..
repeat with new thermostat.. I do this when installing new thermostats.. before install...
could be you have a 180 deg f stat in there now !
Old 03-30-2011, 06:18 AM
Re: coolant temp
it used to rum warmer with the dash gauge pointing to 12 oclock now its more like 1030 thats why i checked it with the scan gauge. Scan gauge says it is going to close loop. I'
ll pop a new stat in and try that,thanks to all.
94 s-10 blazer 4.3 w temp guage! exalteduser Problem Diagnosis 8 08-26-2009 04:54 PM
p0128 coolant temp below thermostat regulating temp ? heffronjr Venture 5 01-12-2008 01:36 AM
High Coolant Temp and Low Coolant Warning Lights flashing scott3689 SC/SL/SW 2 10-25-2007 08:28 AM
1990 735IL coolant temp problem bweera 7 Series 4 07-29-2006 06:40 AM
735i coolant temp problem. viper2m 7 Series 3 06-28-2002 09:55 AM
