Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-29-2011, 12:18 PM
FastJack FastJack is offline
97 Rodeo Intermittent Starting Problem
MY 3.2, manual transmission Rodeo has recently developed a starting issue. When I turn the key the starter always engages as it should. The engine will either fire immediatley or not at all no matter how long I continue to crank the engine. Sometimes I have to turn it on and off 8 or 9 times to get the engine to fire. Once started it runs fine until turned off. My immediate thought is the ignition switch is failing but before I go that route any ideas?
Thanks
Old 03-29-2011, 05:18 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 97 Rodeo Intermittent Starting Problem
try this for the next week. Turn the key to the accessory on position. put on your seat belt. Turn up the radio ... then start the truck.
This extra 10 seconds will give the truck enough time to figure out where the crank-position sensor is at so it can fire correctly and will allow the fuel pump to prime the fuel pressure regulator.
Try it for a week and then report back ....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
The Following User Says Thank You to amigo-2k For This Useful Post:
FastJack (03-30-2011)
Old 03-30-2011, 09:42 AM
Will do. Thanks!
Old 04-15-2011, 11:31 AM
It's been over a week but I didn't get to drive it much. Sunday I started it up 10 times in a row in the driveway and then drove it about an hour. Let it set for two hours and then turned the key on for at least 10 seconds before starting. Took 6 tries before it fired up.
Old 04-18-2011, 11:19 AM
The last few times I have tried your strategy it has worked. I don't know what the deal was on my previous reply. So if the "wait ten seconds" approach works what is the next step.
Thanks,
Jack
Old 04-19-2011, 06:40 PM
Isuzu Guy
It could be the crank position sensor or the fuel pressure regulator is faulty.
You may want to try to post this on planetisuzoo.com (there are lots of isuzu folks there and a couple of Isuzu techs).
-Ryan
Isuzu Moderator
Car Show Tips
FastJack (04-20-2011)
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Intermittent starting problem '98 Rodeo... KJK Rodeo | Passport | MU 3 02-01-2008 08:20 PM
intermittent starting problem arant General Discussion 10 09-17-2004 05:14 PM
Intermittent starting problem bldyblazer Blazer 0 12-11-2003 12:51 PM
Intermittent starting problem PKREYE Caravan | Voyager 1 10-24-2002 12:58 PM
