Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-27-2003, 08:00 PM
ProShift ProShift is offline
Taking off rims
For my freinds birthday I was planning on taking off my freind ugly hubs and putting rims on that are pretty nice (i found them in the junk yard but they are pretty mint) but i would like to suprise him by put the rims on in the nite time so when he wakes up he will be like WOW... so might i do that
Old 05-28-2003, 12:53 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Make sure he doesn't have a gun...might look like your stealing them. First you need to jack the car up and put stands under it, then use the proper sized socket and a cracking bar to take the nuts off, remove the wheel and replace with the new one...reverse steps to put it on...tighten quite tight but don't over do it.
Beer tastes better upside down.
Old 05-28-2003, 02:15 PM
bluetwo bluetwo is offline
actually, the first thing you should do (before jacking up the car) is to loosen the lug nuts. then raise the car, remove lugs, etc...
Black 93 MR2T
Old 05-28-2003, 02:29 PM
Cy@tirerack Cy@tirerack is offline
Ditto on the bluetwo method.
Best to bring a torque wrench with and torque to car manufacturer specs - over tightening can warp rotors.
Old 05-28-2003, 05:45 PM
Thanks :smoka:
