Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 03-29-2011, 08:00 AM
moorjus moorjus is offline
Question wiring help 89 thunderbird
I have a 1989 ford thunderbird. The battery will not charge. I found mice in under my dash. I believe they caused a short as the battery and the alternator are good. I just don't know how to track that down and was wondering if anyone out there knew how and if I could bypass it in anyway just to be able to keep the battery charging for now. I don't know if it makes a difference but I can put a charged battery in and it will drain without the car ever being started or touched.
I appreciate any and all help/input on the matter.
thanks, Justin
Old 03-29-2011, 11:07 AM
tomibraniste tomibraniste is offline
Re: wiring help 89 thunderbird
It s better to go to service, or to buy a new battery
Old 03-29-2011, 11:44 AM
Scrapper Scrapper is offline
AF Premium User
thanks, Justin
when you put battery in did you get a spark off of cable? and yes piney's and mice love to chew on the wires.
Old 03-29-2011, 11:50 AM
AF Premium User
all depends on how long your battery was dead you may check the water in battery see if it's showing any lead thats not covered in water if you can get caps off but if sealed i'd slow charge it and see if it holds a charge? when car is just been setting i take neg. cable off or clock can run it down or a short. but i would get one before it gets cold out.
Old 03-29-2011, 07:02 PM
rhandwor rhandwor is offline
thanks, Justin
Go to Advanced Auto or Auto Zone for a free battery and charging system check.
You can disconnect the battery ground use a DVOM and check for milliamp drain.
Pull one fuse at a time if the drain goes away this will tell you where the problem is located. Also disconnect the alternator and check.
Old 03-30-2011, 04:10 AM
Thanks for all the answers guys. I know the battery and the alternator are good. Those have been tested. I will hafta try doing that with the fuses. At least I might get an idea.
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 11:43 AM
1982 Ford Thunderbird idle SyllyLou Thunderbird 3 08-31-2009 06:55 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
transmission wiring help please danielgast46 F Series 0 02-28-2009 09:33 AM
