Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-28-2011, 08:17 PM
markqc markqc is offline
Oil light On
2007 Dodge Dakota 3.7L V6 2WD SLT
I was driving and the chime went off and I noticed the oil light came on. I was a little late for an oil change (a little over 5000km since last oil change) so I just popped in to a quick oil change place to have the oil change done. Oil level is fine but the light is still on. I tried two times to reset the light by turning the ignition on and pump gas pedal 3 times. (Instructions from the lube place) I figured after a few start stops the light would go out but hasn't yet. I assume this may mean low oil pressure or faulty switch? Temperature gage is behaving normally as well. Anyone else experience this? Any suggestions?
Thanks,
Mark
Old 03-28-2011, 10:51 PM
tempfixit tempfixit is offline
Re: Oil light On
Thanks,
Mark
Personally I would get a mechanical gauge on it to see what the actual oil pressure is before ruining engine if oil pump is bad> It might just be the sensor is faulty but why take the chance.
Old 03-29-2011, 07:19 PM
Re: Oil light On
Dealer changed the oil pressure switch. Light is out for now. We'll see how it goes. Apparently this is fairly common.
Thanks,
Mark
Oil light blinking clemsonfansc Intrepid 7 03-02-2011 07:47 PM
Oil Check Light FordBoss88 Caravan | Voyager 3 01-18-2010 09:56 AM
94 Accord EX oil light xxGriffonxx Accord/TSX/Accord Hybrid 4 10-18-2009 02:12 AM
Does the oil warning light have an oil level switch? dieter Caravan | Voyager 5 08-29-2009 04:36 PM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 06:52 PM
