Old 03-28-2011, 06:46 PM
forkliftfixer forkliftfixer is offline
2002 2.2 ecotec no start
driving down the road then the car stalled .tryed new coil pack no start.once in a while it will pop when i try to start.i used a spark tester on a couple plugs an i have spark.it could be a little stronger but i have spark.i used a gas compatable hot start .no start.if i let the car sit overnight and try to start it it will backfire or pop once than nothing.i even pulled the air box poured fuel into throttle body no luck. i took psi on fuel rail an its at 50+psi.i took a test lead ran it to engine to neg at battery no luck.the main plug that is under air box had been probe and corroded and previous mechanic repaired wire.it was power to dash.this car ran so smooth and strong .
Old 03-29-2011, 10:25 AM
viggy58 viggy58 is offline
Re: 2002 2.2 ecotec no start
are you getting spark? fuel pressure? will is start with a shot of carb cleaner?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 03-29-2011, 06:53 PM
rhandwor rhandwor is offline
Use a noid light and check for pulse at the injector.
Old 03-30-2011, 11:08 AM
noid test good .pulses as should but no start
Old 03-30-2011, 11:24 AM
any other ideas ,cam,crank ,cold temp sensors.
Old 03-30-2011, 04:34 PM
Check for a plugged air filter. Look at timing belt you maybe slightly out of time.
I would check for spark at all cylinders.
2002 Passat 2.8 wont start and only hitting on one cylinder jenseay72 '97+ 0 01-08-2011 02:33 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
