Old 05-27-2003, 07:22 PM
Ethernal Ethernal is offline
b21A1 swap in a 87 si
i need some expert advise, from someone that really knows what they are talking about.
is it a bolt in swap? how easy would it be?
Old 05-27-2003, 08:18 PM
PWMAN's Avatar
PWMAN PWMAN is offline
never heard of a b21, unless it's a B20 bored out.
Old 05-28-2003, 07:49 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yeah what car is a b21a1 from?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-28-2003, 08:23 PM
PWMAN's Avatar
Well, since no one has heard this engine - I will tell you this, all B series requires a mount kit to be put in your civic. Your car now has a D series, and they don't mix. You have to change tranny's and axles too.
Old 05-29-2003, 05:39 PM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
B21A1 is a 90-91 Prelude Si motor.
B20A3 88-91 Prelude S
Carb SOHC 100 HP
B20A5 88-91 Prelude 2.0Si
PGM-FI DOHC 135 HP
B21A1 90-91 Prelude Si
PGM-FI DOHC 140 HP
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 05-29-2003, 06:49 PM
PWMAN's Avatar
Whoa yeah what was I talkin about anyway. He said SI, and somehow I thought thats a model of a civic when I wrote it. I wasn't smokin crack or anything, just had a brain fart I guess. I have no idea what engine is in in 87 SI prelude so I can no longer comment on what engine fits.
Old 05-29-2003, 07:08 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
whats the r/s of the B21, is it better or worse than the B20b?
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 06-01-2003, 12:31 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
its worse. in fact, ive heard that the b21 is the worst b-series motor ever made. lots of rod problems or something along that lines. my friend has a 90 S that we are converting to fuel injection, and eventually putting a b18c1 or c5 into, depending on his cash flow by then end of the summer.
i think the 87 prelude has and A series motor like the old accords, but dont quote me on that.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-05-2003, 10:00 PM
PreludeX PreludeX is offline
Send a message via Yahoo to PreludeX
is your 87 FI? if so than its a b20a5.. umm and far as the the b20b and b20a.. totally diffrent motor.. another thing is b21a1s have really bad oil burning problems! and for the guy with the 90 and goin to put a b18c or c5-- waste of time! ull be better off with the H22A than either of those cuz the motors sit totally diffrent and then ud definatly have to get custom mounts!
Old 06-05-2003, 10:02 PM
Look at the engine code to find out! it located where the tranny and block meet! pretty easy to see.. its a flat spot!
Old 06-06-2003, 02:14 AM
as for the oil burning, i dont care. if its a new engine, it wont burn for a while. its an 87 SI, with the b20a5 i think. all i want to know, is if i need new motor mounts, a mounting kit, or if it is just a bolt on. thanks for the help everyone, but im not asking for opinions. i just want to know about the procedure.
Old 11-13-2003, 04:19 PM
GundamExpo's Avatar
GundamExpo GundamExpo is offline
This wont help your mounting question but I do have some info on the care and feeding of a B21A1. What I gather from browsing posts on preludepower.com is you have to change the oil ever 3000 miles. The piston sleves are made out of some kind of carbon composite and the piston rings chew them up, if I remember right. Supposedly it was an experiment by honda that went horribly wrong.
You might be interested in a JDM B20A
I think its got something like 143HP and a little less torque then the B21A1
Old 07-08-2004, 01:04 PM
ayupit ayupit is offline
Post b18c1 head b21a1 block
hey I am trying to put this little project together. if you guys are saying that the b21a1 motor is bad do you think that I could put another head like the b18c1 on it and make it better?
Old 07-08-2004, 01:07 PM
EF You's Avatar
EF Life Giver
Re: b21A1 swap in a 87 si
not gonna work. the head bolt holes dont all line up. neither do all of the coolant passages.
besides, the head isnt the problem on the b21a1. its the block. its got some experimental coating on the cylinder walls that fails with high mileage and causes them to burn oil.
my buddy with a 90 prelude S is building a b20a block with a b21a1 head on it, and then converting the car to fuel injection. probly not gonna bother with a b18c1 now.
Old 08-18-2004, 10:40 AM
mikeymackinon mikeymackinon is offline
i will be back to up date my info shortly
