Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-27-2011, 11:54 PM
Johnny R Johnny R is offline
0442 code and vacuum leak
99 Malibu LS 3.1L
I've had the engine light on for quite a while, and it always shows the 0442 code (small EVAP leak). As well, the car needs quite a bit of cranking to start, whereas when I got it, to started in a flash.
Over time my shop has replaced Air idle control valve, ERG valve, Throttle position sensor, Intake air temp sensor, gas cap, and GM dealer did the intake gasket manifold. All tune ups and oil changes have been done on or ahead of schedule.
> Apart from being an irritant, would this 0442 code reduce my gas mileage?
> Where would I start looking for the vacuum hoses?
> Would it be best to have the shop do a fog test? I don't like trial and error.
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 04-26-2011, 12:44 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 0442 code and vacuum leak
Originally Posted by Johnny R View Post
99 Malibu LS 3.1L
Did you ever solve this problem with your car? My son's '98 is exhibiting similar symptoms and I've been nominated to solve them. Thanks.
Old 04-26-2011, 09:30 PM
@rkvons - I thought "Wonderful, a reply at last, after my question was up for exactly 1 month." Alas, no reply.
I'm still driving under the same conditions. I must say though, it's a great car, after the initial 4 years.
Johnny R.
Old 06-09-2011, 11:29 AM
rkvons's Avatar
Just an FYI. I went to a junk yard and pulled an EVAP purge solenoid off of a similar car and swapped the one on my son's vehicle and the small vacuum leak went away. The EVAP purge solenoid is located behind the coil pack with a couple of vacuum hoses and one electrical connection going to it.
Old 06-13-2011, 11:21 PM
Thanks for that info. Are these things hard to pull off? I saw a video where a guy had to get under a Saturn to access the solenoid, and then there hardly seemed room to pull the wire and vacuum tubes.
From your description it sounds as if it is on the top, against the firewall?
Johnny R.
Old 06-14-2011, 12:41 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
The first thing that should be checked when getting a P0442 code is a defective or loose gas cap . If you have either condition , it will trigger this code . This is a cheap part and easily replaced regardless of one's mechanical experience or expertise ! After replacing the cap ( making sure the cap is tightened until it clicks three times ) , the " check engine " light on the dash likely won't go off immediately but should in a few days . If not , there may be other more major problems but the gas cap should always be checked first . In my state , part of the emissions testing is to remove the gas cap and put it into a machine that tests it to ensure the cap is functional ! If not , they require you to replace it before you can pass the emission test .
" Sometimes I grow so tired "
Old 06-14-2011, 12:49 PM
rkvons's Avatar
Yes, thanks, already did the gas cap.
Old 06-14-2011, 12:52 PM
rkvons's Avatar
It's on top, towards back of engine. It's kind of a weird bracket that it goes in. The solenoid has slots that fit over the bracket and will require some twisting to get it off. Start from the passenger side. Oh, and I've just been told that the CEL came back on, so I'll have to read the code and see what's up. Maybe I haven't fixed it after all.
Old 06-15-2011, 11:28 PM
I was about to leave for the pick-ur-part when I read that your CEL was back on. Thanks for the post. It's a bit like trying to catch a mouse isn't it.
Johnny R.
Old 09-15-2011, 07:29 PM
rkvons's Avatar
Does anybody know how often the EVAP tests are run on a 1998 Malibu LS with a 3.1? I know that the charcoal canister is purged, but how often? I've read that the computer makes a decision about whether to run tests based on how the vehicle is being used. If someone could shed light on this, it would be great. I do something the may fix the problem, and I don't see the CEL light go on for a few days of driving. Then it goes on. Could it be that the fault is so marginal it sometimes is passing? Any help would be great. Thanks.
Old 09-15-2011, 08:58 PM
Tech II Tech II is offline
They are run every time the car is started and run, ONCE the criteria for running them are met.........
Some factors are coolant temp, time, load, etc.
If all the criteria are not met, the test isn't run.....if the test fails, in some cases it turns the CE light on right away....in some cases, it has to fail on two CONSECUTIVE drive cycles....so, say it fails on a drive cycle....next drive cycle it doesn't even run(because criteria are not met)....next drive cycle it fails, but the CE light does not come on, because it didn't fail for TWO CONSECUTIVE drive cycles...or the next cycle it could pass, and still the light won't come on, because it didn't fail two cycles in a row......
The Following User Says Thank You to Tech II For This Useful Post:
rkvons (09-17-2011)
Old 10-05-2011, 08:46 PM
rxl650 rxl650 is offline
Johnny R and rkvons-
Did either of you solve your problem? I'm also getting the dreaded P0442 code after 177k (2003 Malibu). I've reset the code twice and the code stays off for a couple of weeks then comes back. I've replaced the gas cap but no fix after 300 miles. It looks like others have had issues with the EVAP purge solenoid and Vent solenoids. Any ideas?
Thanks
RXL650
Old 10-05-2011, 08:54 PM
No, I've never resolved the problem. Now it also takes quite a while to crank before it will start. That's embarrassing when I'm with my friends.
Johnny R.
Old 10-06-2011, 07:12 AM
P0442 is a small leak....it could be anywhere.....only a smoke test will find it....
As for your extended crank, try this....turn key to on, then shut off....wait five seconds....turn key to on, then turn key off.....wait 5 seconds and then try and start....if it starts better, then possible check valve in the fuel pump or restricted fuel filter....
Old 10-08-2011, 08:59 PM
@ Tech II - thanks for the idea. I like the process of elimination. But starting did not improve with your tip.
Johnny R.
1997 LeSabre Vacuum Leak? nkmhockey LeSabre 3 12-10-2010 03:20 AM
P0300, P0171 and Vacuum Leaks twdmar Monte Carlo 11 10-04-2010 12:31 PM
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
1997 Saturn SL2-codes and what they mean emmaandleesmom SC/SL/SW 9 10-02-2009 11:53 AM
1870 and 0442 Codes Boehmer Grand Prix 3 07-11-2009 08:59 AM
