Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 05-27-2003, 08:18 PM
BigJ2Kool BigJ2Kool is offline
Send a message via AIM to BigJ2Kool
Angry amp help?????
hey guys. i just bought an amp and 10" sub a few weeks ago and it worked great for awhile. suddenly it just stopped working. now, whenever i turn on the cd player, the amp light goes on for a sec and then goes right out. will someone please help me get this thing fixed?? thanks
josh
Old 05-27-2003, 08:30 PM
red 02 spec v red 02 spec v is offline
you need to check to make sure that the amp is getting power ground and a remote. If it is then try unplugging the sub and see if it comes on. if you have a blowen sub then the amp might go into protect. if it still doesnt come on then try to smell the amp, if it smells burnt then it is junk. What kind is it, what are you running with it?
Nick
Old 05-28-2003, 04:40 PM
alright, I looked more closely, and I am even more confused now. now, when i turn on the car, the red light on the amp goes on right away and it stays on. but when i turn on the cd player, the red light cuts out the second i turn it on. i think that probably means the remote wire is messed up but im not sure. the light on the amp turns on when the car is turned on but turns off when the cd player is turned on. any thoughts?
josh
Old 05-28-2003, 07:27 PM
Your amp should not turn on when the car is off. make sure that the remote is not + when the car is off, check your power conections to see if they are backwards. you could also have a bad ground. make sure that the ground has a clean surface, the paint is scraped of and that you are not using a painted screw. use a volt meter to see how many volts you are getting at the amp and remote, it should be 12v or more.
good luck
Mods: H&R Springs, RS Limited Wheels, Tint, Oz Matrix 6" mid in front Doors, Oz Matrix 1" Tweet in front doors, Oz matrix 6" mid in fabricated Kickpanels, 2 Orion 7005 5 Channel amps, Pioneer 9000 Deck, Orion 300PSW, Oz Matrix Elite 12" Sub freeair in rear deck, Cold air Intake, UR Underdrive Pulley. thats it for now. soon to have header and balance shaft removed.
Nick
