Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-26-2011, 02:15 PM
bigskip13 bigskip13 is offline
clutch not working smoothly
I have a problem with my clutch which is a big issue because I normally love driving my mustang but not lately. It grinds often when I go to put it in third gear and sometimes in 4th. The clutch pedal is all the way down and there seems to be just as much pressure in the clutch pedal as would be normal. If I shift slower than a normal rate then it won't grind but will go in... still pretty rough. It feels like it takes a few seconds for something to stop spinning so that I can slip the gear in. I don't have the know how to fix it so I will be taking it in, just want an idea of how much it may cost and what exactly is going on. Thanks for any help.
Old 04-06-2011, 09:22 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: clutch not working smoothly
Sounds like either the synchronizers in the tranny are getting worn or the clutch throw out bearing may not be extending all the way
clutch not working right bmembry Pick-Up 2 08-28-2010 11:45 PM
1988 ford f250 clutch not working robron7 F Series 1 02-21-2009 03:01 PM
94 LHS AC clutch not working Gripto LHS 2 10-19-2008 10:47 PM
Clutch not working PatHeat Bronco 1 11-01-2004 09:21 AM
hydo clutch not working ravercivicdude '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-04-2003 07:15 PM
Tags
clutch , grind , mustang , problem , shift
