Old 03-25-2011, 05:10 PM
mowen_matt mowen_matt is offline
2000 Blazer Parking Brake Question
I have a 2000 Blazer 4WD, disc brakes front and back. I have been having issues with my rear passenger side. A couple of times when i have gotten home from work I have smelt something warm in the wheel well. I have taken the wheel off and checked the pads and they still had plenty of pad left. I happened again today, so i decided to replace the pads and rotor to see if that would take care of it. When I pulled off the rotor after having a lot of trouble getting it off I noticed that the parking brake could just flop around. I looks like there is a bracket that should hold it in place. Could it be possible that i pulled it off when the rotor came off or that it was already off and it was moving around cusing binding.
Old 03-26-2011, 10:13 AM
old_master's Avatar
Advisor/Moderator
Re: 2000 Blazer Parking Brake Question
Looks like you need to do some work back there. Backing plates, park brake shoes, and a complete hardware kit. Autozone has all of it. The axles need to be removed to replace the backing plates, the rest of it is straight forward.
The caliper pistons have a habit of binding in the caliper bore and the caliper hardware binds in the caliper mounting brackets. Loaded, complete rear calipers come with all of it, including the brackets.
You have to know how it works,
to figure out why it doesn't.
Old 03-31-2011, 05:49 PM
After replacing rear rotors and pads I still had the heat build up even worse with new pads and rotors. Replaced the caliper too and seems like that was the problem.
Old 03-31-2011, 07:32 PM
old_master's Avatar
Advisor/Moderator
Cool! Glad you got her fixed, thanks for posting back.
parking brake vs. car in park...help! CVCchic85 '96-'00 Civic 1 08-09-2010 10:56 PM
Brake questions LUKECIFER Problem Diagnosis 4 06-13-2010 01:16 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 11:14 PM
01 blazer parking brake stuck on!! car4685 Problem Diagnosis 3 10-20-2008 12:49 AM
99 Sunfire Parking brake Question and engine question agco85 General Discussions 0 05-28-2008 09:47 PM
