The security light came on about two days ago, went to leave, light was on, car wouldn't start. Got online following advice of others who seemed to have this problem. I changed the ignition lock cylinder and attempted the relearn procedure as told to do so in manual. Still the security light stays on and I can't keep the car running, it turns over and attempts to start then stalls right out. HELP me!!!
Re: 01 start but stalls security light on
Do you have any third party immobiliser, alarm, remote start or anything that could influence on the signal?
Do you have a worn out key? The BCM is what get the signal for the passlock. You might want to look if the connector is oxidated. it is located under the glove box. Remove the kick panel under it and you should be able to reach it. |
If it were mine, I'd bypass that security system (Passlock II) using the proper resistor. There are numerous procedures in how to do it on-line. I install remote starters, and do it on all remote start installations as part of the normal procedure- so all it 100% of the time.
Go see someone who installs remotes starters and explain that you want yours bypassed pemanently, they can do it if they want to.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
I already replaced the ignition lock cylinder so it's new and new key. I have no other alarm or anything like that on it just the Passlock system, PITA for owners. The BCM seems to be fine, it won't even let me do the relearn procedure so I'm not sure what to do or think at this point. Maybe the PCM? As far as I understand it the BCM just controls like the lights and power switches and the PCM is what controls the engine parts and ignition? Is this correct? I was told to check fuse #37 under the hood that if this fuse goes it can act as a passlock problem so this will be next effort. I've been in contact with a mechanic who is willing to take a look at it for me free of charge, so checking the fuse just may be my last effort before hauling her down to the mechanic. Thanks Guys!
You say that the BCM is fine, then you say that it won't let you do a relearn. Something is wrong between the user (wrong relearn procedure), the new lock cylinder, the wiring, the connectors at both end and the BCM. How do you do the relearn? |
Welcome to AF jaynjess22 !!
Try this if you havnt gotten it fixed. Quote:
1999 Grand Am SS 3.4 OHV
