Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 11-07-2001, 07:19 PM
tf2t tf2t is offline
Question Help on my 2000 Excursion
Someone please help!
How can I disable the seat belt ringer from ringing all the time and driving me crazy other than putting the belt on. Thanks ahead of time for the help
if speed kills do brakes give life
Old 11-08-2001, 06:39 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Have you tried looking for a fuse?
Old 11-30-2001, 02:02 AM
MOJO MOJO is offline
Only one way you can do this.
Look at the drivers side seatbelt. There is wiring that goes to it. You will need to jumper the wiring so it makes a complet ciruit, thinking that the belt is buckled. That is the only way you can get rid of that noise. This feature cannot be disabled.
Old 11-30-2001, 02:04 AM
Nope, wont work. This feature is controlled by the gem module. pull the fuses to it an the truck wont run. We have had cars towed into the dealership due to crap like this.
Old 12-14-2001, 09:03 PM
LiuBei's Avatar
LiuBei LiuBei is offline
I got your solution, get rid of that minature school bus and get something good like a Toyota Sequoia or Acura MDX.
Old 12-17-2001, 08:49 PM
verboom verboom is offline
OK guys, why bother replying anymore? This guy just left the question, he has one post, and has probably never come back since. Besides, if he's dumb enough to drive without a seat belt, he might be dead by now. But if he's still out there, I'd like to be proven wrong, so just add another post there buddy.
Old 03-31-2002, 04:19 PM
LiuBei's Avatar
Excursions aren't really that bad for beeing American made. I've drove a few with the PSD and they rock. Sorry I just don't like American reliability. Although its fun watching cars scatter when you come up on them at about 70mph in an Excursion, HE HE HE
Old 07-16-2002, 07:40 AM
SilverLotus340R's Avatar
SilverLotus340R SilverLotus340R is offline
Send a message via AIM to SilverLotus340R
miniture school bus.. haha thats a good one
Who’d dare build a car without doors or side windows or a hood? Only Lotus. And who’d dare drive one? You would. The 340R is the sports car for people who live to drive and want the whole experience as raw and as pure as it comes.
Old 08-20-2002, 08:53 PM
fordman123 fordman123 is offline
Excursion belt minder
by MOJO That is the only way you can get rid of that noise. This feature cannot be disabled.
The belt minder CAN be disabled on ANY Ford, Lincoln, or Mercury.
It is a customer preference item.
Belt Minder Deactivation/Activation
Preparation
1. Before deactivating/activating the belt minder, set the parking brake.
2. Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
3. Place the ignition switch in the OFF position.
4. Close all the vehicle doors.
5. Unbuckle the driver safety belt
6. Place the parklamps/headlamps switch in the OFF position. (If vehicle is equipped with Autolamps, this will not affect the procedure.)
Deactivating/Activating
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off. (approximately one to two minutes)
3.Note: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parklamps/headlamps on then off.
5. Buckle then unbuckle the safety belt three times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
l--flashing of the safety belt warning belt lamp four times per second for three seconds
l--three seconds with the safety belt lamp off
l--flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation of belt minder disabled.
9. After confirmation, the deactivation/activation procedure is complete.
Old 10-04-2002, 10:45 AM
kgcoker kgcoker is offline
2000 Excursion
Is there a way to disable the ignition key warning bell?
Thanks,
KG
Old 10-04-2002, 11:37 AM
freakray freakray is offline
AF Modelrater
Take the battery out of your truck, then you won't have to worry about any of the warning lights and bells going off
AF User Guidelines
Old 12-19-2002, 10:38 PM
spool spool is offline
Just push in on the drivers side seat belt release button one time...then the buzzer stops. Of course you'll have to do this each time you get in the car but heck, it works!!!
Good luck!
Old 11-15-2004, 02:34 PM
snicker snicker is offline
Re: Help on my 2000 Excursion
Last time I was in Tulsa, I saw a guy that had a device that simply disabled the seatbelt dinger, and if the key was turned on, it would not chime either. That would be great for playing your radio at the lake, or even if you were working on your truck. I'll bet there are mechanics that hear that ding in their sleep. It said "Illegal for driving" on it, but I guess that is a personal decision.
#6 fuse keeps blowing on 2000 Excursion duneswest Excursion 5 08-06-2012 02:43 PM
2000 ford excursion Price... The_last_regulator Excursion 2 09-22-2010 09:52 AM
2000 Excursion mom30075 Excursion 10 01-06-2006 10:22 PM
2000 excursion brakes and turn signal fuse blows gregotowno Excursion 1 01-04-2006 12:27 AM
2000 Excursion runs and stops Bruce Hunt Excursion 8 11-06-2005 12:04 AM
