Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2011, 11:36 AM
bjlasota bjlasota is offline
Wheel bearings part difference
I took my wheel and brakes apart and checked my drivers side bearing last night. The bearing is making noise so I'm assuming that's the problem. When I go to a parts store, the bearing hub assembly they have for my car does not match what's on my vehicle. I've taken a picture of what's on my car and also have a picture attached of what the shops keep showing me. The one the stores have in stock have a gear of some sort on them. I'm assuming it's for ABS, but not sure. My bearing hub doesn't have this gear. Is it ok to put the one with the gear on it or is this really not the right part?
Old 03-22-2011, 01:01 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Wheel bearings part difference
What year and model vehicle do you have? Unless someone swapped hubs on you in the past with the wrong one, I would go with one that's a correct fit. Since the hub on your car is non-abs I'd be sure to replace it with one of the same.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-22-2011, 01:08 PM
It's a 2003 Mustang, V6 model. I understand that it should be replaced with the same hub, but everyone's showing the hub with the gear as the one designed for my vehicle. So, the question is, how do I determine which hub to put on my vehicle?
Old 03-22-2011, 02:04 PM
tempfixit tempfixit is offline
Looks like you have a non abs brake system.
Check out http://www.tascaparts.com/partlocato...?siteid=213668
rockauto.com has it also.
Old 03-22-2011, 05:20 PM
HiFlow5 0's Avatar
Stanger
Have you seen it in person or just off the picture of the computer? I'm listing two different part numbers for your year, one with ABS and one without ABS. If the parts store only sells the one with ABS, and you visually confirmed this, because computer diagrams may be generic, then you next option would be the dealer.
Here are the factory OEM part numbers for your reference.
Front wheel hub;
Without ABS 1R3Z1104BA.
With ABS 1R3Z1104AA
Though from my searches, non ABS seems to be rare, probably a no option car.
-2013 Ford Flex
-1999 Ford F150
Old 03-23-2011, 06:42 AM
Yes, I visually confirmed this at 3 different part stores. I'll try searching by the part numbers you supplied. Thanks.
Old 03-23-2011, 06:59 AM
OK, I found what appears to be the correct hub at tascaparts. RockAuto is showing the geared hub when I enter the part number supplied for non-abs vehicles. One diagram on tascaparts is showing an exploded view of the hub and it appears that the abs gear just presses on. Does this mean they're the same hubs? Can I just pop the abs hub on? Can I press the gear off? I can buy this hub much cheaper locally than if I were to buy from any of the online dealers I've found so far.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
