Old 03-21-2011, 07:41 PM
TimmyGTP02 TimmyGTP02 is offline
Intake gaskets leaking, help?
Hello, so on my 2002 GTP I just brought it to the dealer for the recall on the valve cover gasket and they noted that the intake gaskets are leaking. I figured this would be the case since there is some oil leakage a little bit and was wondering if anyone could suggest the best gaskets to get and also maybe some directions on how to change them?
I've heard that it's fairly simple to do yourself and really can't afford to bring it into a shop to do. I want to get it taken care of before it becomes a large problem. Any help is greatly appreciated!
Old 03-22-2011, 10:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Intake gaskets leaking, help?
Send me a pm and I will send you a file. You can use the revised gm lim gaskets or felpro brand. Is it leaking coolant or oil?
Old 03-29-2011, 10:57 AM
vettepiper vettepiper is offline
I am brand new to this forum so I might be jumping in a little too quick but My GP is non-turbo and a long time ago I had this intake leaking antifreeze which so happened to be finding it's way into my exhaust. This in turn stopped up my Catylatic convertor.
It's been so long that I can't remember the name of the company that sells a permanent fix for the GM problem of leaking manifolds. The fix consists of a complete intake manifold and parts to repair the problem. It was also a reasonably priced part. I'm sure you can find through a search but surely it has been posted on this site before.
Hope this helps.
Old 01-21-2012, 01:56 PM
I just wanted to thank Bob for the email you sent me with the directions on how to change these gaskets. I had the help of a more experienced car guy but your info helped a ton Thanks again Bob! You're the best.
Old 01-21-2012, 11:27 PM
I looked up the repair intake website so here it is:
http://ken-co.com/manifold/default.htm
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
Intake gasket leak or head gasket vfour65 Impala | Impala SS 9 09-02-2008 07:37 PM
3.4 L intake gasket leak online survey by APA CANADA43 General Discussion 0 10-26-2004 09:25 AM
3.4L intake gasket leak online survey by APA CANADA43 General Discussion 0 10-26-2004 09:18 AM
intake gasket leak proteks Trans Sport 4 04-17-2003 09:35 AM
