2002 loud bang from dash
I get a bang(crack) from time to time from the dash area.
I have no clue where it comes from. It sounds like a rock has hit the wind screen. Talking it over with my brother his does it too. He has a 2006 sierra. Any ideas what this might be? Cheers Stripe |
Re: 2002 loud bang from dash
Cheers Viper |
Intermediate Steering Shaft is probably what you are hearing. Notorious for producing a knocking/clunking type sound at low speeds during turns.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work. |
a bang would / should create a vibration. any vibration in the occurance of this ? If so the steering components need attention . also shocks mounting hardware .. HVAC ducting doors can make noises at times. sounds are hard to diagnose too many areas of the potential source. could even be the drivetrain . when this occurs give vehicle operating details. speed, turning , shifting,stop,start etc.... |
Thank's all.
This noise only happens 3-4 times a year. It is not affected by turning or any other action it just does it those 3-4 times a year. We think it is an HVAC door or a loose weld/rivet in the fire-wall. I thought a lot of others would have had this noise.(and found the cure) Again Thank's All Cheers Stripe |
I also have a 2002 with the same problem you have, a loud crack coming from the dash near the steering wheel. My truck does it everyday and I think it is the plastic or fiberglass in the dash that expand when it gets to a certain temp. in the cab
Only notice we had was very cold or hot at start-up. We don't have the only 3 that do it. You could be right too. Cheers Stripe |
