Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-21-2011, 07:48 AM
Rmasters3 Rmasters3 is offline
Rough start, ignition noise
Recently I have had a rough idle and some surging on start-up on my 2001 Rodeo Sport V-6. I notice this mostly on colder mornings, after sitting overnight and almost never any other time. Also have noticed some ignition noise in the radio, but only when under a bridge or overpass, and can't say if this is new or just something I recently noticed. No CEL or codes. Fuel filter was replaced when the sender and pump were replaced a year ago. Engine has about 85K on it. Plugs have maybe 50K on them and never been a problem--OE Iridiums.
Any ideas?
Old 03-21-2011, 08:06 PM
Cat Fuzz Cat Fuzz is offline
Re: Rough start, ignition noise
Remove and clean your throttle body. It would also help to know year/model/engine as well but from a few clues I assume late 90's early 2000's Trooper or Rodeo. I'm guessing 2000+.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 03-30-2011, 09:42 AM
I cleaned the throttle body. Still had the issue this morning, although it was more of a too high idle than rough. On start it raced to 2,000 RPM plus, and settled down a little. Idled higher when in gear than in Neutral.
Old 03-30-2011, 10:20 AM
Scrapper Scrapper is offline
AF Premium User
have you tryed ajusting tps? and run some sea foam threw it to clean injectors.
Old 03-30-2011, 10:50 AM
I have not tinkered with the TPS on this, and am not sure how to go about that. Where is it and how?
Old 03-30-2011, 09:14 PM
OldLugNut OldLugNut is offline
My initial thought is to rule out any problems with the Idle Air Control valve (IAC) and Exhaust Gas Recirculation (EGR) valve. Sometimes these can get bits of carbon stuck in them that can affect idle by letting more unmetered air into the intake stream. A little more air coming in here can affect idle & still not trip an OBDII code. Both of these items are easy to get to on the Isuzu 3.2 V6 & easy to clean (except the EGR pipe that runs inside the manifold plenum). There are probably a number of posts on this site that give details on how to clean them. Let us know when you find the problem.
Old 03-31-2011, 10:08 AM
amigo-2k amigo-2k is offline
Isuzu Guy
This sounds like a classic intake manifold gasket issue. See the FAQs for more details.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-31-2011, 10:24 AM
AF Premium User
ok i'll check for that dam moter is packed in there.
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
89 F150, Hard Start Ignition or Fuel? JAGSARGE F Series 10 11-16-2010 11:41 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 05:03 PM
97 Lumina No strat/rough start/loud noise/backfiring..... smithc_08 Lumina 5 11-01-2009 03:52 AM
99 Ford Windstar Starts Off Rough,Makes Strange Noise Sometimes Dies kyrra28 Windstar 6 12-29-2006 11:46 AM
