| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Help with amp choice
I honestly dont know squat about amps. So if someone could give me a quick barney style tutorial that would be amazing.
I havent ordered all of the speakers yet. But here is what I plan on ordering... 2 Component speakers to go in door panels 2 Tweeters to go in door panels 2 12 inch Subwoofers 2 three way speakers I suppose the amp I am going to need will be based on the amount of RMS wattage of all the speakers and subs. Is that correct?
Michael Glisson - Semper Fidelis |
Re: Help with amp choice
normally, I would get a 4 channel amp for the mid/tweets in the doors or front area - maybe 100 watts RMS/ch X 4. Skip the back speakers all together. Get at least a 500 watt RMS clas D mono amp for the subs, that puts out max power into 1 ohm. Get subs that are dual 4 ohm so the final load will be 1 ohm when you wire everything in parallel.
So you are recommending me get 2 amps? One for the front speakers and one for the subs. Is that correct?
speakers in the rear is a stock set-up, these set-ups are usually average at best. You can also go the 5 channel amp route and just get 1 amp OR get a 4 channel amp and use the front 2 channels for the front speakers and combine the rear two channels (called bridging) for a sub. Are you going to use the stock headunit or an aftermarket one ?
So its better to go without the speakers in the rear and just the sub or subs. Is that what your saying? Either way I am going to need either a 4 or 5 channel amp right?
yes, if you want to keep the "body count" down, you will need a single amp that is a 4 channel or a 5 channel. Your choice mostly depends on whether you want seperate amp channels for the mids and tweets. You also have to ask yourself how much bass you really want. The 5 the channel of a 5 channel amp or the bridged output of the two rear channel of a 4 channel amp are NOT going to provide enough power to pound the pavement.
The reason most people ditch the rear speakers is becasue in a STEREO recording, you only need a pair of speakers. Rear speakers are for surround sound in a home theatre environment and there are painfully few titles of real music recorded in 5.1. |
you can certainly do that, just won't be very loud. Subs should be fine on a 500 watt amp (rated for the load the speakers are wired for)
