Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Exterior | Wheels | Tires
Exterior | Wheels | Tires This is the place for all exterior modifications including wheels and tires.
Old 03-19-2011, 05:55 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Tire question
Hey folks, quick tire-type question for the Forum.
Car in Sig, currently OEM front tires and Bridgestone Potenza Pole Positions in the rear replaced about 2k miles ago. Fronts are in desperate need of replacement and I have a choice to make: either get two more Bridgestone's for the rear and move the current rears up front, or grab 4 new Firestone Firehawks. The Pole Positions are all-season and the Firehawks are Summer-only.
I'll be purchasing from Tirerack.com unless anyone knows of a cheaper place. How much risk would I be taking if I purchased two Firehakws and tossed them on the rear? I know mixing brands is somewhat taboo, but since both will be on the same axle does it lessen the impact?
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 03-19-2011, 06:17 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Tire question
Do you mean the Firehawk Wide Ovals?
I compared the specs, and they are pretty close. But the Firestones do not last as long as the Potenzas, which indicates they are a softer compound, and will get better traction especially on dry pavement. Also, the larger tread blocks means less tread squirm so they should feel more precise during hard and fast cornering.
The Potenzas will last longer and get better traction in bad weather, but will have slightly less dry-pavement traction. Also they might feel slightly less precise during hard cornering due to the smaller tread blocks.
I think your choice depends on your use. If this is your only car, and you use it for lots of commuting, daily driving, and higher mileage, just get 2 more Potenzas.
But if this is only for occasional use, weekends, high performance, autocross use etc, go with 4 Firehawks.
Finally, IMO do not mix the two brands. I think things will get pretty squirrily during hard cornering if you do that.
Old 03-19-2011, 06:40 PM
Scrapper Scrapper is offline
AF Premium User
Re: Tire question
i would go back to brigestone i don't think much of firestone and get a alignment. and keep up the air in the tires not what the tires sais of pressure there should be a sticker on you drivers side door what psi you should run.
good luck.......
Old 03-19-2011, 06:47 PM
inafogg inafogg is offline
Re: Tire question
personally i'd go with 2 more bridgestones exspecially if it is a daily driver
not sure if i'd rotate,just put them up front & rotate in 4k
not a big fan on firestone,but have had good luck with br/stone
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-19-2011, 10:50 PM
Re: Tire question
Thanks for the replies. It's not a daily driver, rarely sees travel in the winter months, 2002 and only 21,xxx miles. I'll have periods of spirited driving, but by no means is it anything approaching autocross stuff or extreme cornering, or anything requiring god-like traction. I read all the replies and I think I'll stick with adding two more Bridgestones at the moment - should save a bit of money too.
Thanks again
Winter tires - speed rating & downsizing Hello: A couple of questions for the forum. I have an 07 Camry LE. I am buying winter tires for her. I am jtmann Tires and Wheels 3 11-18-2010 09:07 AM
Kooky Tire Pressure Question RidingOnRailz Engineering/ Technical 13 02-02-2010 09:16 PM
Tire Substitution Question 195/50/16 for ? cjulia 323/Protegé/Familia/Etude/Allegro 1 12-10-2009 06:54 PM
Another Tire Question MiltSA 1st Gen 95-99 4 12-20-2001 01:18 AM
