Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-18-2011, 06:16 PM
bilfro bilfro is offline
2000 Lincoln LS Heater Problem
Get no heat from either the Driver or Passenger side although the A/C seems to work OK. Have bled the air from the cooling system with no effect.
The DATC diagnostic initiation sequences given in my 2000 shop manual differ from those for the 2002 LS given in an earlier thread. Pressing the FLOOR and OFF simultaneously, then the ON, displays the code sequence: 0,25; 1,24; 2,23; ..... 25,0;
88,-188. Pressing PANEL and OFF simultaneously, then the ON, displays just the 88,-188 terminator.
What can I do to obtain meaningful diagnostic codes?
Old 03-18-2011, 06:28 PM
nuckolsk's Avatar
nuckolsk nuckolsk is offline
NUCKOLS
Re: 2000 Lincoln LS Heater Problem
soleniod or sensors in drivers compt. see shrodd's posts. im doing the famous clunk fix now and at solenoid is in the way of the sway bar bolt
Old 03-18-2011, 06:30 PM
nuckolsk's Avatar
NUCKOLS
solenoid or sensors . see shorod's posts. doing famous clunk fix tonight and that solenoid is in the way of sway bar bolt
2000 Buick heater problem Christos42 Century 8 07-23-2014 06:27 PM
2000 Lincoln Ls Problems with misfiring natesr70 LS | MKZ 2 03-03-2008 12:25 PM
2000 Ranger heater problem?? Todd400 Ranger | Courier 2 01-19-2005 11:42 PM
2000 jimmy heater problem dmoney002611 Blazer 0 01-05-2005 10:18 PM
2000 Sonoma Heater problem 65gto69 Sonoma | S-15 1 09-24-2004 08:03 PM
