Go Back   Automotive Forums Car Chat > Honda > Jazz | Fit | Logo
Old 03-18-2011, 03:31 PM
RangerJ RangerJ is offline
Honda Fit fuel filter
2008 Honda fit. Where is the fuel filter? Thanks
Old 03-18-2011, 04:20 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Honda Fit fuel filter
I believe it will be in the engine bay before the fuel line connects to the rail.
Most likely attached to the firewall.
Can you trace the in feed line back towards the tank?
Old 03-18-2011, 05:58 PM
BullShifter's Avatar
It's in the tank.
Old 03-18-2011, 06:54 PM
Moppie's Avatar
Master Connector
Originally Posted by BullShifter View Post
It's in the tank.
That would make it harder to find then
I gather it's attached to the bottom of the pump, and can be accessed through the top of the tank?
Old 03-18-2011, 07:34 PM
Yes you will have to drop the tank & remove the pump. Those kind of filters are only serviced when the pump fails. Not sure if the Fit has an access hole inside the car to get at the pump, uncommon for Honda's. The older Civic's could be accessed without removing the tank, that's only one I know of.
Old 03-18-2011, 07:39 PM
Moppie's Avatar
Master Connector
All of the 90's cars should have an access hole, either under the seat, or boot floor.
My Civic, Prelude and Accord do or did.
The post 2001 cars are all built on a different platform, so may need the tank dropped.
Should be easy to pull the backseat and lift the carpet to find out though.
Old 03-18-2011, 08:03 PM
I don't understand why all cars don't have access holes. Nothing worse than dropping a 30+ gallon tank that is full. Some of the Accords(98-02) need to have the rear frame dropped in order to get the tank out. That's exactly the reason there so should be an access hole!
Old 03-18-2011, 09:23 PM
Thanks for all the replies and info.
Old 03-18-2011, 10:43 PM
Moppie's Avatar
Master Connector
Let us know how get on with fixing it.
Be interesting to know if there is access from in the car, or if you have drop the tank.
Old 03-18-2011, 10:48 PM
I can look it up tomorrow at work. We have very few Fit's that come in.
Old 03-23-2011, 04:03 PM
Thanks for all the replies,The car has not acted up since I posted, so maybe it was bad gas or some trash.Daughters car never drove it.Thanks again.
Old 03-23-2011, 11:57 PM
Moppie's Avatar
Master Connector
Good news!
Hopefully that's it's only hick up
1991 Honda Accord fuel filter renchhednot Accord/TSX/Accord Hybrid 0 03-19-2010 09:10 AM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
