Old 03-18-2011, 08:38 AM
Dwarakesh Dwarakesh is offline
Smile Help me for design calculations
Hello everyone
I'm little trouble doing the design calculations for an 75cc engine which i'l be using for my project.
Its specifications are
1.Bore=46mm
2.Stroke length=42mm
3.Piston dia=46mm
things to be found,
1.I need to calculate the original cc of the engine
2.Force on the piston
3.Input and output torque
Thank you all
Old 03-19-2011, 08:38 AM
Smile Re: Help me for design calculations
Pls help me guys
Old 03-19-2011, 09:10 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Single cylinder engine? Look here to calculate engine displacement.
http://www.mathsteacher.com.au/year9...r/cylinder.htm
As for the others? Force? Torque? These are dependent on may factors in engine design and cannot be calculated from the minimal details given.
Old 03-19-2011, 11:02 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
This took a little time to remember, but here's what I did:
Total volume is given as 75cc. Compressible volume is the calculated cylinder:
PI*(46/2)^2*42=69800 cubic mm=69.8cc
Compressed volume would be 75-69.8=5.2cc
Determine compression ratio:
75/5.2=14.423:1
At intake cycle, assume air pressure in cylinder is 1 atmosphere (atm). Thus, compressed pressure is 14.423 atm. Also assume that the air/fuel mix is compressed adiabatically...the mix doesn't heat up due to compression.
Let's also assume for simplicity that gasoline is composed of octane C8H18 and in gaseous form and combustion is complete. The chemical equation for it's combustion is:
2•C8H18 + 25•O2 --> 16•CO2 + 18•H2O
The ratio change in gas pressure will be 34:27 after combustion. Remember though that only the 21% oxygen in the air is consumed. So, only that partial pressure will be affected. The partial pressure before combustion is:
21% * 14.423 = 3.029 atm
and after combustion is:
3.029 * 34/27 = 3.814 atm
Assuming adiabatic combustion, total chamber pressure is:
14.423*0.79 + 3.814 = 15.208 atm
Maximum force on the piston is just after TDC. Area of piston head is
PI*(46/2)^2= 1661 mm^2
Using conversion from atm to pascals (Pa or N/mm^2), force would be:
15.208*(.101325 N/mm^2)*1661= 2559.6 N
Now assume that maximum torque occurs half way through the combustion cycle. Chamber volume is:
5.2 + 34.9 = 40.1 cc
Assuming adiabatic expansion, use gas law to determine new pressure:
P1•V1 = P2•V2
15.208•5.2 = P2•40.1
P2 = 1.972 atm
Torque arm length is equal to the crank throw or 1/2 the stroke length, 21mm or 0.021 m. Torque is calculated to be:
1.972*.101325*1661*0.021= 6.97 N•m
Calculating the torque at just past TDC would require some force vector calculation, but this is a good start I think. Hope this helps!
Man, what a way to celebrate my 2,000th post!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
Dwarakesh (03-26-2011)
Old 03-19-2011, 04:51 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
There are considerably less intelligent ways to do it
Now we wait while Curtis checks your math...........
Old 03-19-2011, 05:58 PM
MagicRat's Avatar
Good post, jd,
What I was trying to get at was the engine configuration. A 14.4:1 compression ratio is virtually unusable in a 4 stroke configuration, which tells me the engine design is actually a 2-stroke.
One can apply the same math if one knows the height of the ports in the cylinder wall. The engine would only develop compression after the ports have been closed by the piston moving upwards.
For example, if the top of the port is half-way up the cylinder wall, the effective compression ratio would be cut in half, or 7.2:1.
Furthermore, the total compressible volume of the engine would also be cut in half, reducing the total fuel/air mixture available for combustion.
The Following User Says Thank You to MagicRat For This Useful Post:
Old 03-20-2011, 10:29 AM
jdmccright's Avatar
The RustBuster
Yes, the high compression ratio isn't normal for a 4-stroke and not for a small engine that was given. But I just rolled with what I was given. At the least, I laid out the major steps of the thought process. Thanks for the nod.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 03-25-2011, 05:40 AM
Thank u ppl for helping me, its a 2 stroke engine only. These calculations were of gr8 help. Million of thanks
Old 03-25-2011, 10:05 AM
jdmccright's Avatar
The RustBuster
Your very welcome and good luck on your project.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 03-25-2011, 11:59 PM
Dear jdmccright, in this eqn PI*(46/2)^2*42=69800 cubic mm=69.8cc, what is PI and what value hav u substituted for it.
Thanks
Old 03-29-2011, 12:19 PM
jdmccright's Avatar
The RustBuster
PI is pi. 3.14159265.... If you have to ask that question, then I would say that you have more than a little trouble on this project's calculations. Good luck.
[EDIT] I will also say that you can adjust the cylinder pressure for the change in gas temperatures as it is compressed and combusted using the same Ideal Gas law: PV=nRT, but you'd have to estimate the temperatures.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Design - Volvo XC60 R-Design 2011 - you like this style? ProBoarding Cross Country/XC70/XC90 1 02-03-2011 03:02 AM
Man Arrested For Infiltrating Ford to Steal Designs for the Chinese iafb83 Automotive News Desk 0 10-15-2009 10:56 PM
Help for Yoshida Designs tire stencils Jekill Car Modeling 0 11-01-2005 05:12 AM
enclosure for re10 calculation roach666 Car Audio 1 02-16-2005 07:47 PM
Need Help For Designing My Ride edgho99 Exterior | bodykits | Lighting 4 06-12-2003 09:52 PM
