Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-15-2011, 10:36 PM
rednaxela_03 rednaxela_03 is offline
91 corolla... front end vibration
I just recently change my car from auto to manual.
when i am driving at 60mph to 70 mph the driver tire vibrates
pretty bad.
after 70 smooths out
if i hit any bumps while driving 40+ mph it sounds like it is hitting very hard like i have no suspension on that side.
i also hear something that sounds like metal washers vibrating together while driving
the cv axle does seem to be a little loose where it goes into the trans.
could this be the bearing in the transmission.
or could it be something else.
if it is the bearing is it easy to change?
also the tire have been balanced and check and they are good.
any ideas and help would be greatly apreciated
Old 03-16-2011, 11:05 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 91 corolla... front end vibration
When you swapped for the manual tranny, did you also change out the CV joints and hub bearings? You need to tell us all that you have replaced to do the swap.
As for the tire vibration, it could be a bad or loose tie rod, sticking brake caliper causing rotor warpage, or worn bushing.
The CV axle should have no play at all. Again, you should make sure you have the right axles for the manual tranny and that they are fully seated. There is a c-clip style retainer at the tranny end of the axle to hold it in. You have to sort of ram it in to get it fully seated and engaged. Once it is in, the axle end (closest to the tranny) should not slip at all...a good hard tug will let you know it is seated. If it is not, the integral slip joint in the CV axle will not have enough space to slide and "give" to allow the suspension to move up and down.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 09:17 PM
2000 Corolla front end vibration claytonduk Corolla/Matrix/Voltz 6 04-20-2009 09:47 PM
WTB '94 Corolla Front End Parts cameryfan92 Classifieds 0 10-30-2005 08:48 AM
Tags
vibration
