Old 03-15-2011, 09:52 PM
BE Snowplowing BE Snowplowing is offline
Tempature Gauge
Hey all,
I have a 2000 Chev Silverado 5.3L 4X4 extended cab with 265,000 km, can anyone tell me where the temp gauge should be sitting when at normal operating temp.
The gauge on my truck starts at 75 then half way is 100 then the red zone is 125.
Thanks
Brian
My Vehicles:
1989 Chev 3500 4X4 6.2l Deisel
1994 GMC Suburban 4X4 5.7l
1998 Buick Regal 3.8l
2000 Silverado 4X4 5.3l
Old 03-16-2011, 05:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Tempature Gauge
Originally Posted by BE Snowplowing View Post
Hey all,
Thanks
Brian
You should first check truck actual running tempt.
Should be around 195-200 degrees depending on stat.
Then see if the gauge is reading actual tempt.
Where are you getting the 75-100-125 readings and what are they in?
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
BE Snowplowing (03-17-2011)
Old 03-16-2011, 08:58 AM
j cAT j cAT is offline
Re: Tempature Gauge
Hey all,
Thanks
Brian
the numbers you gave are deg C. so this temp should be just to the left/below 100deg C. my 2000 sil runs at 190-195 deg F ...
this is the reading on this vehicle for the past 11 yrs.
If the temp rises above this when plowing I suggest you check your cooling system for proper operation and fluid being clear / not cloudy with particles. thermostat should be replaced at 3-4 yr intervals with the coolant replacement. only use distilled water with dexcool.......
when filling coolant leave cap off tank with engine running , this removes the air that gets trapped/ rev engine a few times air should bubble out.
If the coolant system is good then you may need a large transmission cooler if this temp is high when plowing only............
The Following User Says Thank You to j cAT For This Useful Post:
Old 03-16-2011, 09:46 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Tempature Gauge
Unless you have replaced the thermostat with a lower temperature unit, it should sit just below the 100°C mark after the engine is fully warm and no hard work done.
Plowing involves a lot of transmission shifting and low-speed maneuvering, which will hike up the cooling system temps. I would be surprised if you don't already have a separate transmission as well as steering fluid coolers to go with your plow package (this is inferred from your username).
I'd also suggest a transmission fluid temperature gauge. Newer trucks might already have the temp sensor, it just needs to be accessed through the OBD port. Otherwise, you can buy a gauge for about $60.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
Old 03-17-2011, 07:24 AM
Re: Tempature Gauge
A great big thank you for your help.
My temp gauge sits just below the 100 degree C. mark, and runs fine, I was only asking because on my Suburban the temp gauge sits at around the 85 degree C. mark.
One last thing, Yes I have a tranny cooler, but it was mentioned about a power steering cooler??? is there such a thing, and where would I go to get one.
Thank you again
Brian
My Vehicles:
Old 03-17-2011, 09:17 AM
jdmccright's Avatar
The RustBuster
Re: Tempature Gauge
The Burb thermostat may have been replaced with a lower temp one sometime in the past. No big deal, cooler is usually better for older trucks. Newer ones (circa 2003 or so) are more particular for emissions control...some set a SES light if they detect too low coolant temperature.
As for the steering fluid cooler, most GM trucks have some sort of rudimentary cooler, usually consisting of an extra length of bent tubing routed in/out of the front end of the box frame...looks cheesy but I guess it works for the 98% of people who don't make their trucks really work.
You can plumb in any aftermarket tube/fin cooler, and it probably doesn't need to be very big. In fact, just found this on the Advance Auto website:
http://shop.advanceautoparts.com/web...0D_A%7CGRP2070
All I'd say is that I'd recommend the cooler be painted to help combat the salty roads. You could use a high-temp black paint like for barbecues, just be sure to spray straight into the fins to get better penetration.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 03-17-2011, 11:18 AM
Re: Tempature Gauge
Thank you again
Brian
with the temperature operation. on any vehicle made with cat converters and especially aluminum engine components never use the wrong thermostat. the engine must run at the design temp. too hot or cold causes problems. sometimes expensive problems.
sure some vehicles have coolers for the power steering . they are small in size, 3 tubes about 8 inches long on my vehicles.
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Car Audio 10 12-03-2010 12:49 PM
SBC tempature sporadic??? help!! palmer6691 General Discussion 7 10-21-2009 02:28 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
Installing a oil tempature gauge. darkserpant Cavalier 0 05-22-2005 03:03 PM
Water Tempature Gauge Problems livinloudhonda '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-28-2004 01:57 PM
