Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-15-2011, 01:34 PM
ridds79 ridds79 is offline
2001 malibu 3 problems
my malibu has a mass air flow sensor code p0102, replaced sensor with a used one and still getting the same code. it is also slaming into gear when you shift out of park seems the worst when going into drive, and it is stalling sometimes seems to do it the most when the car is warm and under a half tank of gas. could all of these be caused by one problem? any ideas what might be going on?
Old 03-15-2011, 02:00 PM
Scrapper Scrapper is offline
AF Premium User
Re: 2001 malibu 3 problems
used one may be bad if your getting same code? have you looked and seen if you can take that apart and clean screen?
Old 03-15-2011, 02:34 PM
no i havent what can you use to clean them?
Old 03-15-2011, 03:33 PM
AF Premium User
autozone has it in spray it's for throttle body cleaner but it will work to clean screen.
The Following User Says Thank You to Scrapper For This Useful Post:
ridds79 (03-15-2011)
Old 03-16-2011, 03:43 PM
any idea if that mass airflow could be causing the other problems? i cleaned with gm throttle body cleaner still no change. the hard clunk into drive worries me the most any ideas one person had the same problem said they changed the IAT i dont know what that is do you
Old 03-16-2011, 04:29 PM
AF Premium User
clunk like it's in your tranny? check the unaversal under your hood on the sterring rod coming from sterring whell also have someone pull in gear while you look at engine see if it's raising to much like moter mount's and tranny mount.
2001 malibu problems copdills Malibu 0 07-09-2008 11:25 AM
2001 Malibu Problems jonas111 Malibu 1 04-06-2005 08:15 AM
Problems with Alternators on the 2001 Malibu? firebringer Malibu 2 09-28-2003 12:56 PM
2001 Malibu Problem!!!! yeunge Malibu 4 07-01-2003 01:54 PM
