Old 05-27-2003, 02:29 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
polsihing problesm
tried to polish my skyline,but still had orange peal, so i sanded the roof to test it out, (3m 2000 grit) and then i tamiya compounded, and meguiars Step 2 Polish... AND I CAN STILL SEE SCRATCHES!!!!!!!!!!!im very pissed off.... Now i want to clearcoat, but im afraid the scratches will still show!!!11
it looks horrible and im panicking!@
Old 05-27-2003, 02:37 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
You still have orange peel around the edges that needs further sanding. Once you get that done, rub the compound on in a circular motion and put some pressure on it. Friction is necessary for the compound to work, it kind of burnishes the paint so it can then be smoothed. It looks like you're on the right track, a litle more practice and you'll have it.
Old 05-27-2003, 02:59 PM
Re037 Re037 is offline
Send a message via AIM to Re037
yeah, you need more sanding. continue with the 2000
moo moo
Old 05-27-2003, 03:49 PM
Integra14's Avatar
i know i have plenty more orange peal, but i was focussing on just the center, i can't get the scratches out,
and also...'
can i still clearcoat? if i compound/polsih?
Old 05-27-2003, 04:09 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
now i see, it looks like your just polishing in straight lines. try going in a circular motion like mentioned above. the scratches whould dissappear that way.
Rui
(modeling) = Click Here
Old 05-27-2003, 05:05 PM
935k3's Avatar
935k3 935k3 is offline
If you really want a better paintjob that takes less rubbing out do what I always do. Prime then sand. Spray on 2-3 coats of paint and sand that down(after drying 1-2 days) and put on a final coat or two. These last coats will always be better than the first. I would sand that coat down and put one final color coat. Clear is not really necessary unless you use a metallic color. Wait a couple weeks to final polish as some of the scratches come from paint that isn't fully cured yet.
Old 05-27-2003, 09:22 PM
hirofkd's Avatar
hirofkd hirofkd is offline
No need to get pissed. That's how it's supposed to look more or less.
You need either higher grit sand paper, such as 3600 - 12000, or polishing more.
Try one direction, then perpendicular to it, and finally circular. That should take care of it.
Hiroaki Fukuda
Old 05-27-2003, 10:04 PM
dvdfreak dvdfreak is offline
I think it the sand paper is giving more scratches than expected, try apply plenty of water and sand very lightly when you are finnishing the sand ant turnning to compond.
Old 05-28-2003, 12:35 AM
ljrlude01 ljrlude01 is offline
Send a message via AIM to ljrlude01 Send a message via Yahoo to ljrlude01
not to hijack your thread but could I use a 1500 to sand down the orange peal look. I can't find nothing higher than 1500 around here.
01 Boosted Prelude
90 Nissan Skyline GTR
Mi-4
"current projects"
92 Honda Prelude,Ballade CRX
"finish project"
Skyline R34 GTR
Old 05-28-2003, 07:49 AM
T\/\/iN-Tu|2Bo's Avatar
T\/\/iN-Tu|2Bo T\/\/iN-Tu|2Bo is offline
Are you "WET" sanding it???
"If you feel in control. You're not going fast enough" - Mario Andretti
Old 05-28-2003, 10:21 AM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
After the paint coats have dried, I sand my model car with Tamiya Finishing Abrasive No.2000 in a basin of water. I would sand and dip the kit into water regularly, to ensure the sanding process is always wet but not totally immensed in water while sanding. The regular dipping also helps to remove clogged "sand dust" on the surface of the kit. And I got a nice smooth finish to it.
Also, I sand it lightly and in circular motion. As such, I would do this while half-watching the TV since it easily takes me 2 to 4 hours. (this is one of the model building steps which I currently enjoy.)
I hope this helps.
Old 05-28-2003, 10:37 AM
Martbee Martbee is offline
I'd be panicking too... that's the finish you have before finishing ?? All of you ?? Man, when I have something like that to finish, I sand back to the plastic (with the water processus) and redo it.
1995 3.8 Engine Problesm Worse When Hot Benesesso Trans Sport 3 12-03-2007 07:06 AM
