Old 03-14-2011, 08:24 PM
rcflydog rcflydog is offline
starting problems 94 v6 camero
Just picked up this car for my son ,then started to have problems, u can turn the key on and some times it will turn over ,and others nothing , all indacator lights are on but nothing, then u can go back out and try it and its fine any advise ?
Old 03-14-2011, 08:41 PM
brcidd's Avatar
brcidd brcidd is offline
Re: starting problems 94 v6 camero
Security light status? is it on? does it flash?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-14-2011, 11:09 PM
yes security light is on
Old 03-15-2011, 10:17 AM
brcidd's Avatar
Then your VATS key resistor is dirty, or your ignition switch contacts are having trouble. The resistor pellet in your key can be cleaned with rubbing alcohol-- or just rub it 22 times on your pants to shine it up- then try it again. But you must wait 4 minutes for that pesky security light to go out between tries.
If this does not work- try your other key.
Ultimate solution- is to bypass the VATS (vehicle anti-theft system) by selecting a resistor of same resistance as the key pellet- and soldering it between the little white wires encased inside the bright orange sheath, that runs along side your steering column. Be sure to cut the wires free from the ignition tumber first- before installing resistor between them.
I've done several VATS systems this way- works great- there are only 14 possible resistor values- I have a chart if needed.
'99 GMC Yukon
Old 03-15-2011, 07:56 PM
Thank u much Ill give that a try
Old 03-15-2011, 09:04 PM
That seemed to work ,I did have to wait untill the security light went out but it started, thank u. I would like to bypass this altogether, I found the two wires, could u draw out for me how to souder a resistor in between them, and how do I determined what size resistor needed? thanks agin
Old 03-15-2011, 09:29 PM
brcidd's Avatar
You need a DVM (digital volt meter) so that you can set it on resistance measuring, and touch the two leads to either side of the chip pellet in your key. I usually secure the key head in a vice to hold it still while I touch both side of the pellet. Once you measure the resistance, go to Radio Shack (or anywhere else that sells resistors) and buy the value of the designed resistance in the table below that best matches the resistance you measured. You may need to buy a couple resistors that add up to the designed resistance-and solder them in series- or better yet- buy a $1.50 potentiometer, and "dial-up" the needed resistance. (Radio Shack salesman love to help you decide what to buy)
If you don't have access to a DVM- go to Radio Shack and let the sales guy measure your key for you- they love to show off their DVM skills. Then tell him to select the resistor method for you.
GM only used the values of resistors in the pellets that are in the table below- so that they only had to stock 15 different key blanks.
Then once you cut the orange sheath from the ignition cylinder, open it up, and find two very tiny white wires. Solder the new resistor across the two white wires that lead to under the dash (not the key cylinder- let those wires hang free- they no longer are needed). You will never see that security light again, and you can now have keys cut that do not have a resistor pellet in them-- save money on spare keys- only $2 instead of $14.....
'99 GMC Yukon
Problem starting latorawilson Impala | Impala SS 8 04-29-2011 03:14 PM
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
94' k1500 starting/electrical problem k150094 C/K 0 08-21-2009 10:47 PM
Help! Starting issue sunfire96 Problem Diagnosis 5 04-12-2009 11:57 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
