Old 03-14-2011, 07:49 PM
GregGP GregGP is offline
PCV valve
This is probably a stupid question, but do the '97 - '03 3800 SII N/A engines have a PCV valve?? If they do, I sure as hell can't find it..
Old 03-14-2011, 07:52 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: PCV valve
Yes they do. Passenger side of the motor, in the upper intake manifold, near the MAP sensor. I wish I could explain it better. Maybe someone has a picture.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
The Following User Says Thank You to tblake For This Useful Post:
GregGP (03-14-2011)
Old 03-14-2011, 08:17 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: PCV valve
Just like Tim said it's at the passenger side, right under the MAP sensor. Remove it and then turn the casing counterclockwise, take it off and you'll see the valve.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 03-14-2011, 08:27 PM
Re: PCV valve
Awesome! Thanks guys!! I definately wasn't expecting it to be there.. I was looking for a vacuum line like the older models.
Old 03-15-2011, 12:20 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: PCV valve
don't forget to remove the black o-ring from the old PCV valve and reinstall it on the new one or you'll get a vacuum leak that could trigger a check engine light.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-15-2011, 06:12 PM
rickisrad rickisrad is offline
Re: PCV valve
here is a picture, same on the plastic intakes. it may take some muscle to get off. lube the new o-ring to make it easier to twist back on.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 03-27-2011, 11:21 AM
zepol zepol is offline
Re: PCV valve
Is it in the same place for a 2001 GTP?
Old 03-27-2011, 05:09 PM
tblake's Avatar
In God We Trust
Re: PCV valve
No, the 2001 GTP will have a cap on top of the supercharger held on by two bolts, towards the drivers side.
Old 03-28-2011, 03:03 PM
Re: PCV valve
Thanks TBlake! I found the PCV valve under the little black steel cap that was closest to the driver side on the supercharger. I changed the valve but I couldn't find the gasket available anywhere on the internet. Even GMpartsdirect doesn't list a gasket for this. I just left the old gasket on there and capped it back up but it was cracked and I know that this can cause an issue if I don't get a new gasket there soon.
Old 03-31-2011, 10:37 AM
richtazz's Avatar
Re: PCV valve
Zepol,
that PCV cover gasket is GM part#24503777, and lists for $3.93. Any GM dealer should be able to order it for you.
Old 03-31-2011, 10:40 AM
Re: PCV valve
richtazz You are the freaking man!
Old 03-31-2011, 11:50 AM
richtazz's Avatar
Re: PCV valve
@ Zepol, I get one right every once in a while...
Old 04-01-2011, 09:25 PM
Re: PCV valve
Zepol.......or use rtv for the gasket. I used the high temp red and worked fine. I took it off and it crumbled, I did not want to wait for it from the dealer.
Old 04-05-2011, 04:11 PM
Re: PCV valve
Not one dealer in AZ stocks this gasket. Looks like High Temp RTV it is.
Old 04-05-2011, 04:45 PM
inafogg inafogg is offline
Re: PCV valve
we are talking about an o'ring, go to your local auto parts store
they will be able to match it up.rtv... not a good idea
if you give them the part # they can go from there
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
PCV Valve Replacement CCMphysician General Discussion 0 01-13-2010 12:36 PM
PCV Valve carmic General Discussion 3 01-26-2004 07:41 PM
PCV Valve??? ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 11-20-2001 02:25 AM
