Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-14-2011, 03:58 PM
scherp scherp is offline
Changing door bushings
My Montana is a 2001 and the front door bushings are wearing out. The doors sags a little and hits the latch when closing. It looks like each hings has two small rivets that need to come out. Has anyone done this and have some advice?
Old 03-14-2011, 05:01 PM
danielsatur danielsatur is offline
Re: Changing door bushings
Check your local Auto parts store for Dorman auto parts section,
they should have the brass bushings and pins that are needed.
See http://www.automotiveforums.com/vbul...d.php?t=894065
Old 03-15-2011, 06:12 PM
Thank you for the link, but the Montana has two rivets in each hinge not one long pin. Should I take the hinges off the vehicle or do I chisel the heads off, cut the heads off or is there some other way that would be better?
Old 03-15-2011, 06:18 PM
Leave the hinges on body, remove the door, and use a small disk grinder for cutting.
Old 03-16-2011, 03:27 PM
For the bolts that hold the hinge onto the door are the nuts welded onto inside of the door frame or is the door frame threaded or will the nuts fall off when taking the bolts out? And what is the best way to support the the door while the hinges are off?
Old 03-16-2011, 03:50 PM
The nuts are probably spot welded inside the door.
Make sure you use a good helper, floor jack, or a hoist to hold the drivers door.
Caution - Be careful of the electrical buss line going into the door, it's probably best to disconnect the battery.
door bushings billybob6110 Camaro Discussions 1 05-13-2006 01:31 AM
1995 Jeep GC - Driver Door Bushings 1BADGTO Grand Cherokee | Grand Cherokee SRT8 0 01-21-2005 01:03 PM
Anyone replaced rear door bushings? 2gmSees Yukon 0 03-01-2004 03:45 AM
1997 S10 Door Bushing Replacement chainshot S-10 1 01-30-2004 03:44 PM
