Old 03-13-2011, 10:26 PM
vassa's Avatar
vassa vassa is offline
Williams FW16
Here's my first wip on AF. I've decided to do a wip on the Williams Fw 16 from Model factory hiro. This is my first multi media kit I'll be attempting,and it is a full detail kit so progress will be a little slow. I will be attempting to add some more details as i progress through this, with CF decals and a heap of detail nuts that I have aquired from ,Scale motorsports, scale hardware,and rb motion.As well as some extra wiring not in the kit.I shall start with the customry pics of the bits and pieces in the box. As you will also see i have made a start on some painting and CF work. At present Iam drilling out for the bolts in the heads and the exhaust manifold.
Thanks for looking
Regards Wayne
Old 03-14-2011, 05:40 AM
stevetriumph's Avatar
stevetriumph stevetriumph is offline
Re: Williams FW16
Hi Wayne,
nice subject and a great kit to start out with. MFH have great detail and supply almost everything you need. I must admit I have only ever looked in other peoples boxes as the cost prohibits me from buying. I am still kicking myself for missing a MFH Aston DB4GT on ebay, BIN for £140, the closest I'll ever get I think.
Looks like you are off to a good start and the extras you are adding should make this model a stunner.
Regards,
Steve.
Old 03-14-2011, 03:34 PM
robrex's Avatar
robrex robrex is offline
Re: Williams FW16
Good luck with the build Wayne!
Rob
Old 03-14-2011, 04:19 PM
123yokomo's Avatar
123yokomo 123yokomo is offline
Re: Williams FW16
awesome kit bro
Old 03-14-2011, 04:21 PM
vassa's Avatar
Re: Williams FW16
Thanks Rob. A small update .I have re carboned the plates on the heads,re painted the block ,drilled holes and added detail bolts on the heads and exhaust flanges. Started to add engine wiring. And made the exhausts a bit more detailed.I flattened some small solder wire to simulate joins and used smaller wire for weld seams.They were painted aluminium metalizer,then some burnt metal,buffed and some blue heat staining.Also added very small brackets a couple of bolts and the wire sensor cable.
From here I made a scratch throttle cable
and added a few more wires.
Thanks.Regards Wayne
Old 03-17-2011, 12:52 AM
vassa's Avatar
Re: Williams FW16
I have made more progress. I dressed up the fuel rail a bit from this
to this
I have put the rear end together along with some carbon work, extra details and a bit of wiring.I wanted to dress up the rear suspension /pivot arms a little. It was a big decision to cut the piece up but it turned out alright.
From here I moved onto detailing the brakes. I drilled out and inserted some nut & stud bolts the one on the left has been detailed. Bit hard to see the difference in pic but worth it in real life
The calipers received some bleed nipples and a balance pipe with some detail nuts.
I also wanted to give the front suspension some extra details.Once again it was a hard decision to cut these white metal pieces and play around with them. Its taken a while to get right and I have only made one side. So here is a couple of pics and a mock up shot.
I also have the engine and trans mounted :
Thanks for looking
Old 03-17-2011, 01:41 AM
sportracer02's Avatar
Re: Williams FW16
Looks great, nice details!!
Micha
Old 03-17-2011, 02:57 AM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
Re: Williams FW16
This detail is amazing Vassa. Good to see you back on here, could this be a QMHE best in show contender when done?
or
Old 03-17-2011, 03:22 PM
endac's Avatar
endac endac is offline
Re: Williams FW16
Off to a great start. Keep up the good work
Old 03-19-2011, 05:12 PM
pawlie's Avatar
pawlie pawlie is offline
Re: Williams FW16
Looks great - looking forward to more updates!
Old 03-20-2011, 03:21 AM
ben_gsr2s's Avatar
ben_gsr2s ben_gsr2s is offline
Re: Williams FW16
super expensive kit..
i like your attention to detail..
will follow this built
Old 03-20-2011, 04:54 AM
jaykay640 jaykay640 is offline
Re: Williams FW16
Great job on the detailing! Looking forward to see more progress!
Old 04-01-2011, 04:42 PM
quadzero's Avatar
quadzero quadzero is offline
Re: Williams FW16
You sure put alot of detail into your builds, great for us to follow along. Keep up the good work.
Go Webber!
Old 04-01-2011, 05:02 PM
eyckles's Avatar
eyckles eyckles is offline
Re: Williams FW16
Nice work on the engine. I will certainly follow this WIP.
Lesley
Old 04-03-2011, 01:23 AM
vassa's Avatar
Re: Williams FW16
Thanks for the comments guys. Some small progress. I've been detailing away with the steering wheel,dash,seat,sidepods and associated parts.I removed the moulded buttons on the steering wheel and replaced,the same was done for the dash with some CF work
Not sure whether to change the buckles on the seat belt for other style??
The parts that go on the sidepods were a liitle bit bare
so I decided to dress them up a little with what reference I have and with more CF.
These all will have wires attached later.
Thanks for looking.
Regards Wayne
MFH Williams FW16 out of stock? ferrari2k Car Modeling 13 03-24-2009 01:20 PM
WIP MFH Williams FW16 Brazil GP willster127 WIP - Motorsports 17 04-20-2007 01:48 AM
MFH 1:20 Williams FW16 - a left hand project allnie WIP - Motorsports 46 01-02-2007 05:54 AM
Williams FW16 + Driver ferrari2k Car Modeling 4 10-12-2006 08:53 PM
Williams FW16 refs lotus123 WIP - Motorsports 2 05-16-2006 08:37 AM
