Old 03-12-2011, 06:36 PM
xavi.ordonez xavi.ordonez is offline
95 Silverado Temperature Sensor
I have a 1995 5.7 Silverado with a Temperature Sending Unit Wire reading 12.7 volts while disconected from the Sensor. Temperature Sensor OMHs seem with in specs. Once i connect it to the sensor there is no Voltage Reading Avaliable it just reads 0
Old 03-13-2011, 09:26 AM
j cAT j cAT is offline
Re: 95 Silverado Temperature Sensor
measure the resistance of the sender to ground ..depending on the temp it should vary ...measure resistance cold engine , then when engine is hot. post back what you got. if it is not changing get new one measure resistance cold/ place in boiling water measure resistance before install .....now you will be sure of what the problem is.
cold temperature gauge decprelude Integra 5 09-12-2011 11:28 AM
4T60E transmission temp sensor clutch492 Grand Prix 8 12-02-2009 07:17 PM
01 Silverado Coolant Temp Sensor wiring okieguy Silverado 1 08-10-2009 07:39 PM
Silverado-temperature switch stuck on air cond. HARLEY1 Silverado 0 02-16-2007 09:44 PM
