Old 03-11-2011, 02:48 PM
Fred_Bear Fred_Bear is offline
p1345 driving me crazy
my truck, a 99 s10 zr2 4.3 has the annoying p1345 code. It runs great. But Im tired of the SES light on.
I have checked and double checked. My distributor is in correctly. I have replaced the distributor drive gear. I have replaced the cam sensor. The cap rotor and plugs are new AC delco.
The code only appears when I start the engine. If I erase the code after the engine is started it will not reappear until you shut off and restart the engine.
does ANYONE have a idea what it could be????
Old 03-11-2011, 04:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: p1345 driving me crazy
Have you checked /set the camshaft retard?
What is it reading now?
MT
Old 03-11-2011, 07:31 PM
old_master's Avatar
Advisor/Moderator
Only 3 things will cause P1345 to set:
1) As MT mentioned, Camshaft retard not within spec: must be zero degrees + or - 2 degrees @ 2,000 RPM.
2) The distributor is off a tooth.
3) Crankshaft position sensor data is incorrect and needs to be relearned. This alone will NOT set a DTC, but it could cause the P1345 to set if the stored data is incorrect.
You have to know how it works,
to figure out why it doesn't.
Old 03-11-2011, 11:38 PM
I'm thinking it must be camshaft retard or offset. I have checked everything else. and replaced the cam position sensor and drive gear. Now I am in search of a scan tool that will measure cam offset.
Old 03-12-2011, 05:34 AM
MT-2500's Avatar
AF - Advisor
10-4 on that.
Also first step.
Make sure the 6 on dist base is lined up with rotor when no 1 cylinder is at TDC compression.
If READING IS 25 DEGREES or more off
Check the dist plugin and wireing plugin.
I have found bent over pins on the dist plug.
Let us know how it goes.
Good Luck
MT
Old 03-12-2011, 08:35 AM
I'll check those pins. The rotor is pointing directly at the #6 while at TDC no doubt about it.
Old 03-12-2011, 08:53 AM
MT-2500's Avatar
AF - Advisor
Start with reposting in the right forum.
And removing the cheap chiana link form you post.
This was to jhnhook1
But I see he has done been whacked.
MT
Old 03-12-2011, 09:24 AM
MT-2500's Avatar
AF - Advisor
10-4 let us know what you find.
Sometimes you have to get a small mirror in there to see them.
Good luck
MT
Driving Test Exam question serge_saati COMPLETELY off-topic 4 01-12-2011 01:29 PM
Crazy Acccident fjmustak Car Videos 2 11-23-2010 02:02 PM
Nj car meet, holiday food drive Becky0Prelude94 Car Shows 0 11-17-2009 10:25 PM
How to put the drive belt back? serge_saati Windstar 9 10-25-2009 07:55 AM
86 caprice. 305 to 350. drive shaft lengths? m3gas3th Caprice 11 05-12-2009 10:40 PM
