Old 03-11-2011, 02:05 PM
edford edford is offline
ford escort 1.9 1995
the check engine light on after i changed motor and tranmission every thing hooked upp. do you know what i can do to check it or turn it off ? thanks
Re: ford escort 1.9 1995
also the check coolant light o also
Old 03-11-2011, 02:13 PM
702VegasLife's Avatar
702VegasLife 702VegasLife is offline
What code pops up?
Old 03-13-2011, 07:59 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
I changed an engine awhile back and had the same problem. I was getting the code for the cam position sensor.... turns out the new engine I bought didn't have the piece on the end of the cam that the sensor reads from... had to pull the cam out
If this turns out to be your problem, the engine will run fine and is safe to drive- but you are losing fuel economy. Rather than sequential fuel injection all 4 cylinders will fire in batch mode on every stroke.
You need to find out what your code is for the light.
Old 04-05-2011, 01:36 PM
zzyzzx2 zzyzzx2 is offline
Who made this "new" engine?
Old 04-06-2011, 07:15 AM
Davescort97 Davescort97 is offline
Escort guy
Take it to Advance or Auto Zone and they will read the code for you for free. If it was a one-time code and not a recurring one you can disconnect the negative battery terminal to erase the light. Not a good fix because the light will probably come back on again if it is an ongoing problem.
Old 04-06-2011, 08:19 AM
Advance or Autozone reads EEC-IV codes?
Old 06-19-2011, 12:58 PM
Jamesjjr9110 Jamesjjr9110 is offline
My 91 Escort E-Brake and (I want to say) CEL light came on when the wire to the starter from the ignition switch came off... Might look around for any loose wires...
92 ford escort...1.9 litre lifter prob jetta4j Escort 2 09-06-2008 03:01 AM
Escort 1.9 wont idlee indypacetruck Escort 1 06-26-2005 07:05 PM
'94 escort 1.9 no acceleration poobear1959 Escort 7 05-17-2005 10:46 PM
93 escort 1.9 quit/timing belt intact chcowboy Escort 2 01-17-2004 12:45 AM
