Old 03-10-2011, 02:11 PM
tempfixit tempfixit is offline
tire size question
Has anyone had a set of 195/60/15 tires on your windstar. I have a chance to buy some alloy wheels with above size tire on them off a 99 Vovlo S70. According to tirerack.com the rims should fit as they are 5 bolt 108 bolt pattern. I know the speedometer will be fast but other than that any handling or heigth probblems???? They are Blizzak tires.
thanks
Old 03-10-2011, 02:24 PM
12Ounce 12Ounce is offline
Re: tire size question
The concern would be ..... will the interior of the wheel clear the brake assemblies front and rear ... and will the tire be "centered", inside/outside, as it should be. Lots of things to examine.
Old 03-10-2011, 02:47 PM
Thanks 12Ounce,
Tirerack windstar specs: Tirerack Volvo:
Offset: 40mm /////////////35 or 40mm
Backspacing 5.55" ////////5.35 or 5.55"
Bolt Pattern 5-108 ////////5-108
UPDATE: These rims and tires were on craiglist, I did not look at them but he could not find a make or model number on the rims to get the complete specifics, also the tires were not good.
Old 03-11-2011, 04:33 PM
parkerb parkerb is offline
i've ran 205/70/15 blizzaks for many years. speedo is off about 5mph (fast) at 70.
Old 03-12-2011, 11:25 PM
catvents catvents is offline
Originally Posted by tempfixit View Post
Thanks 12Ounce,
The other concern for me is not about the Volvo'rim but the tire size; 195/60/15 has a load index 87, so the max load on 1 tire is 1201 pounds at 35 pounds pressure. the Windstar ( if mounted with 15 inches wheel) has 215/70/15 tire size, load index is 97 so 1609 pounds capacity. With this smaller size tire, you are short of over 1600 pounds of weight capacity. I would not drive my 4000+ pounds Winnie with this smaller size of tire, matter of security and handling.
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
Tire size question NebraskaDragon Ram Pickup | Ram SRT10 5 08-31-2005 02:49 PM
tire size question ogre Tires and Wheels 4 04-04-2003 02:11 PM
Tire Size question... Stormy Rodeo | Passport | MU 1 10-15-2002 05:32 AM
1998 Accord Tire size question ehomer Tires and Wheels 1 04-09-2002 02:55 PM
A simple tire size question G20Rob3 Cosmetics 5 12-28-2001 02:11 PM
