2000 GP vibration under acceleration - right turns
2000 GP 152K miles - when I'm on a cloverleaf or equivalent long curving right turn I get a vibration through the left side only when I'm under accelleration. I've had both left side wheel bearings replaced and have had a local garage take a look under the front end and they claim everything seems tight. Anyone have any ideas?
Thanks. |
Re: 2000 GP vibration under acceleration - right turns
Agreed, CV could be the issue.
I'm having a similar issue but it has nothing to do with turns. The weird thing is that it will only do it while accelerating between 35 and 45 MPH. If I'm above or below that speed it doesn't do it. It got really bad so I replaced my control arms, bushings, ball joints, rack and pinion, TRE's, motor mount and got an alignment (I didn't replace those things JUST because of this shaking problem - they needed to be replaced on their own merits...or lack thereof). That improved the problem but didn't cure it. If I'm coasting at any speed it drives as smooth as butter, it's just once the gas pedal is pressed it starts shaking if within that MPH I mentioned above.
Do you think my problem is the CV shafts as well? I have no clicking or anything on turns and turning seems to have no affect whatsoever. Could it be anything else?
![]() ![]() 2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C 2000 Jeep Grand Cherokee Limited 4.7L V8 ---------------------------------------------------- 1996 Chevrolet Camaro Z28 5.7L V8 1993 Chevrolet Suburban K1500 5.7L V8 1991 Ford Probe LX 3.0 V6 1986 Ford Tempo GL 2.3L 4 cyl. |
Yeah. Maybe rotate your tires and see what happens.
take a look at the struts/springs maybe cracked
is the vibration coming from front,back,or hole L.side
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
I'm religious with tire rotates and I just took off my snow tires and put on my summer tires - no change.
I'm betting it's the axle. There is no play on the wheel bearing and these shocks are only a year or so old. When I changed my control arms, I had to put a new clamp on the cv axle and noticed it wasn't very full of grease so I'm betting that's it.
sometimes if you get under there and get a good grip on the cv axle you can get it to move more than it should. shake it up and down and in and out. if there is abnormal movement then replace it. at 152k it is time to replace anyways.
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
I had a similar problem with my 99 GP on right turns. I don't know if I would describe the occurance as a vibration but rather a loss of power that caused the car to stumble until I pulled out of the turn.
Turned out to be a faulty valve in the transmission. (Pressure Control Solenoid Valve Assembly) ...thought your vibration might be kind of like my studder. GL
2005 Chevy Equinox LT 186,000 mi 2004 Buick LeSabre 200,860 mi 2011 Infinity G37x 103,000 mi |
I knew my driver side axle was bad because when the inner boot popped off, the joint was totally dry. I replaced the driver cv axle, but I'm still having the same annoying shaking occur between 35-45 MPH when the gas pedal is pressed. I'm at 161K miles and the passenger side is still the factory axle. Unlike the driver side was, the passenger is completely free of any leaks or cracks in the boot. I guess what I can do since the driver side is brand new is try to wiggle that axle and then just compare it to how the passenger moves. This shaking is REALLY getting on my nerves and my entire suspension and steering systems are virtually brand new.
Ok. Well I'll be chaning the oil here soon so while I'm under there I'll compare the two shafts and hopefully the passenger one is bad (and fixes this shaking problem). Otherwise I have no clue what this could be.
Well last night I changed the oil and tried shaking that passenger axle and it seemed rock solid. What's weird is that a month or so ago I did the same thing and felt a tiny bit of play. Could it have healed? lol
I'm totally stumped on this one. Should I just replace the passenger axle for kicks and see what happens? I hate throwing money at this car w/o knowing what's wrong.
