Go Back   Automotive Forums Car Chat > Hot Deals
Hot Deals A place to find and discuss the best deals online.
Old 03-09-2011, 12:02 AM
blazee's Avatar
blazee blazee is offline
Problem?
Harbor Freight Daily Deals weekending 3/13
Click each coupon to print it or use the number code to order online.
MONDAY 3/07/11 ONLY
60" Hardwood Workbench with 4 drawers.
Link
Description of Windsor Design 93454
Workbench top has a protective lacquer finish, and includes four storage drawers, each felt-lined to help protect your fine tools. Workbench also includes a bottom shelf for larger tools.
  • Four felt-lined storage drawers
  • Convenient storage shelf
  • Wood block vise with adjustable machined guides
  • SAVE EVEN MORE - Use your MONTHLY SAVINGS BOOK Coupon Code to save even more on this product!
Tools sold separately.
Weight capacity: 250 lbs. (top), 25 lbs. (each drawer) Vise capacity: 7” Table top dimensions: 60” L x 20-1/8” W Shelf dimensions: 47-1/4” L x 14-3/4” W x 2-1/2” H Drawer dimensions (x4): 21” W x 12-3/4” D x 3” H Overall dimensions: 60” L x 20-1/8” W x 33-1/4” H Shipping Weight: 115.00 lbs.
TUESDAY 3/08/11 ONLY
2 HP, 8 Gallon, 125 PSI Portable Air Compressor
Link
Description of Central Pneumatic 67501
Affordable and portable air supply for powering nailers, general shop clean-up, airing tires and inflating sports equipment.
  • 2 horsepower motor (rated)
  • 125 PSI maximum
  • Air delivery: 4.5 SCFM @ 90 PSI, 5.5 SCFM @ 40 PSI
  • 8 gallon tank capacity
  • Oil lubrication
  • Decibel Level: 88 dB at 1 meter
120 volts, 15 start-up, 14 running amps 60 Hz 3360 RPM 125 PSI max working pressure Air delivery: 4.5 SCFM @ 90 PSI, 5.5 SCFM @ 40 PSI Air outlet: 1/4"-18 NPTF Shipping Weight: 66.15 lbs.
WEDNESDAY 3/09/11 ONLY
Bigfoot Panel Wagon
Link
Description of Haul-Master 32826
You remember the little red wagon you had as a kid, and now your children or grandkids can enjoy that same type of pull wagon. Or you can use this wagon to take gardening tools and supplies out to the yard.
  • 33-5/8" x 15-3/4" x 5-1/2" deck
  • 5-1/4" wood panels
  • 10" pneumatic tires for all terrains
  • Max. weight capacity: 330 lbs.
Ages 5 and up.
Ages 5 and up. Shipping Weight: 35.50 lbs.
THURSDAY 3/10/11 ONLY
36 Piece 1/8" Steel Letter/Number Stamping Set
Link
Description of Pittsburgh 800
Hardened high-carbon steel stamps are designed to withstand up to 9000 strikes.
  • 26 letters A-Z and "&" sign
  • Numerals 0-8 (turn "6" upside down for "9")
  • 1/8" high characters
  • Organized in a protective case
Shipping Weight: 1.38 lbs.
FRIDAY 3/11/11 ONLY
Pack of 50 15" x 13" All Purpose Shop Towels
Link
Description of Harbor Freight 46163
For tough-to-clean messes like grease, oil and grime, this pack of 50 absorbent shop towels is a must.
  • 50 shop towels, each 15" x 13"
  • Ideal for all types of light- to heavy-duty industrial cleanup jobs
  • Stands up to machine-washing for extra long life
Dimensions: 15" x 13" Shipping Weight: 3.10 lbs.
SATURDAY 3/12/11 ONLY
3 Piece Decorative Solar Light Set
Link
Description of One Stop Gardens 95588
This 3 piece decorative solar light set is a perfect addition to your yard and garden, and costs nothing to operate! Color-changing LED inside the transparent hummingbird, butterfly and dragonfly constantly cycles from red to green to blue once dusk falls. 1-3/4"-square solar panel hangs on each stake, and charges the built-in AA NiCd battery in direct sunlight, so once dusk comes, the light show automatically begins.
  • Solar panel charges the battery during the day
  • LED turns on automatically at dusk
  • Changes color in a red-green-blue sequence
Includes three 30" tall stakes Shipping Weight: 1.50 lbs.
SUNDAY 3/13/11 ONLY
32 Piece Screwdriver Set
Link
Description of Harbor Freight 90764
  • Heat treated carbon steel shanks
  • Soft grip handles
Includes: Fourteen screwdriver bits (Four slotted, six Phillips and four hex) Four slotted screwdrivers Three Phillips screwdrivers one combo 1/4" nut driver/pick up tool one flexible 1/4" nut driver one pocket screwdriver circuit tester AC 100-250V with pocket clip one 1/4" nut driver with magnetic T-handle and seven swivel screwdrivers Shipping Weight: 3.24 lbs.
Harbor Freight vacuum bleeder giving me trouble Dekeman Windstar 4 03-11-2011 03:21 PM
Harbor Freight Fuses RickMN Engineering/ Technical 1 11-17-2007 12:34 AM
