Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 03-08-2011, 11:40 PM   #1
rickpilgrim1
307 for my 1978 van?
With gas at $3.59/gal and a DOA 350 in my 1978 G-20 conversion van I'm re-thinking the 400sb thing and thinking the 1973 307 I have may be the wiser way to go. I have a set of the L69 305 heads w/mild porting done,(my sons gen 3 Camaro headache), a set of aftermarket hyd roller lifters(Howard), the 383HT GM cam, a performer intake and EDL-1404 500cfm carb. Also have a set of 1973-1987 truck headers and the van has 2 1/2 dual exhaust allready. Also have the complete ignition system,including all the sensors for that L69 305, if not that the DOA 350 has an Accel HEI that works in any sb/bb standard deck engine plus all the chrome odds and ends.
The van has a TH-350 trans with a doug nash od unit that works great, and is 3.54 rear axle. Also tips the scales just shy of 5K, at 4957 lbs and that's with a 1/4 tank of fuel(aftermarket 50gal tank) and 1 person.
The 350 that was has a hole in the block from #2 rod, but at 194K mi thats ok, I have a good 1972 400 sb and the 73 307 that was rebuilt 487 mi before the truck was totalled. All the people tell me to junk the 307 and go 400 as the van is heavy and fuel mpg of 16 is good allready and the 307 will be worse than the mostly stock 350 in power and mpg. We all know gas is only going to get worse so ..........
Never had or drove a 307 chevy powered anything in my life so if anyone has any thoughts or opinions I'd appreciate it.
rickpilgrim1 is offline   Reply With Quote
Old 03-10-2011, 11:20 AM   #2
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Re: 307 for my 1978 van?
I agree the 307 will most likely be underpowered and will thus use more fuel than the 350. The 400 won't be better than the 350 for reasons of economy, but it will have some killer torque.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Old 03-11-2011, 02:16 AM   #3
rickpilgrim1
I was thinking that way at first also, but chevy did put 305 TBI motors in the newer vans, not to mention this won't be a stock 307 2bbl anymore, it will be more like the 235hp marine 307. With the OD unit I can change the 3.54 to 3.73 easily without a great milage penalty... As to the 400, we have a long rod, port reworked, recammed and offy intake eqipped 400 in our 93 3500 4x4 dually and while it is better for all around power than the 6.5 diesel the fuel useage is only about 11mpg and thats with a 4l80E od trans and 4.11 gears. Not to mention the van does not have room for the big radiator the truck has to keep it cool.
best replacement carb for 1978 454 burban shamububan C/K 2 03-09-2011 12:11 AM
chevy 307 for sale joe68 Cars/Parts for Sale/Exchange 0 10-03-2007 10:16 PM
transmission mounting problems 307 for Chevy sb 350 Raptorus1 Cutlass Series 1 10-29-2005 01:52 PM
Replacement Carb for 1978 model 454 in a Suburban shamububan General Discussion 1 10-07-2003 10:11 AM
i need vacume diagrams for 1978 celica slickshoes Celica 0 12-14-2002 02:06 AM
