Old 03-07-2011, 11:45 PM
dpizzarella dpizzarella is offline
How to remove Throttle Positioning Sensor???
I have an 88 Honda Civic 1.5L I need to replace the Throttle Positioning sensor on it. But it has some safety nut holding it on normally it’s a Phillips screw I can’t figure any way to remove this? Any help would be great. Thanks
Old 03-08-2011, 06:06 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: How to remove Throttle Positioning Sensor???
You have the stock bolts still in it. Take a chisel and a hammer and start hammering in the direction to take the bolt out....or take a dremel tool and cut a slot in the bolt and use a flat head to remove.
Tony
91 Civic Sedan DX - Stock 287k Miles
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
How Long For ECM to Adjust to New Throttle Position Sensor? MikeS21 LeSabre 4 03-15-2008 10:55 AM
HOW DO YOU ADUST a TPS Throttle position sensor? wkumale Cherokee 4 12-06-2007 11:24 AM
Throttle Position Sensor/Throttle Switch Adjustment westsidex Metro 3 05-24-2004 06:17 PM
