Old 05-27-2003, 11:35 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Turbo CTR?
does anyone know, or care, if i can run a turbo setup on my b16a with CTR pistons? would the compression be way too high?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-27-2003, 12:29 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
Well if you know what you are doing and have fast knowledge of how to tune a turbo setup, you could theoretically run a pretty high compression. I know that Sport Compact Car mag. ran a Toyota Matrix turbo at 11:1 compression and ran some pretty high boost. You might want to check out their site and look at their "Project Matrix" and see how they delt with the high compression. I think the key would be a really good valvetrain and some beefy connecting rods and REALLY good tuning of the boost control.
Old 05-27-2003, 01:01 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
Don't do it. CTR pistons yield to high of compressoin for safe boost on a stock block. Your cylinder pressures would be too high also. If you want to run boost, use some lower compression or stock compression pistons. Also, a copper headgasket or something stronger than stock would be suggested. If you have CTR pistons already, squeeze a 50 shot wet on it and be happy with that. The fact that you have chosen CTR pistons should be to have more power daily, reliably from higher compression. Best of luck and "squeeze the fun out of it!" (remember squeeze-its?)
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Old 05-27-2003, 02:27 PM
SiZ's Avatar
SiZ SiZ is offline
You'd need to upgrade your rods obviously, and good fuel managment will be the deciding factor in whether or not you blow up.
"The nympho of info, I'm fuckin' what ya heard"
Old 05-27-2003, 03:24 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
if i remember correctly, sport compact car blew that matrix up. they said something about it make lots of noise and then only running on 3 cylinders
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-27-2003, 05:37 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Dude, I remember squeeze-it's those were sweet!!
Anyway, I agree, CTR + Boost is a bit too risky unless you really know what you're doing.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 05-27-2003, 07:02 PM
91civicDXdude's Avatar
it would probably be a better idea if you were to strictly run 118 octane race fuel, but thats stuff's like $20 gallon
Old 05-28-2003, 09:46 AM
crxlvr's Avatar
ok so maybe ill keep the ctr's and stick to my all motor plans.
if i ran a 50shot would i have to upgrade anything else. this is my setup as of now.
B16A
Crower Stainless Steel Valves
Crower Titanium Retainers
BPM Dual Valve Springs
CTR Cams
CTR Pistons
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-28-2003, 11:32 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh i agree. It'd be safe to run high cr turbo if you got all that shit upgraded. It puts more power to the ground than lower compression. You CAN'T boost as high as lower compression but you'll be just as fast or quicker than someone boosting high. Its all about tuning man. Thats one thing thats very important. Get it tuned right away if i was you. If i was gonna go boost i would go high compression!
Old 05-28-2003, 11:34 AM
mellowboy's Avatar
No not really. If you go 60 or higher u need to upgrade ur fuel pump and rail. Its still not a bad idea to do that now.
Old 05-28-2003, 02:08 PM
hmmm...sorry melt, only if you run a dry setup. A wet kit has it's own fuel solenoid which will supply fuel with the nitrous. A dry kit uses your cars computer to read lean/rich conditions and add subtract fuel. In that case you will need to upgrade the fuel pump and also have your injectors cleaned, checked, upgraded for safety. In my opinion it is plain stupid to run dry kit unless you have upgraded fuel pump and injectors and have a way to tune them such as an AFC.
A 50 shot on the CTR pistoned B16 should be plenty safe but don't be stupid with it. Good luck.
91 hatch Si
Old 05-28-2003, 03:22 PM
mellowboy's Avatar
umm i'm guessing he would've gone with a wet set up. and i'm not melt
Old 05-28-2003, 04:44 PM
damn, your not are you? Ha, my bad.
Sure, it is always suggested to upgrade the fuel pump when making upgrades and especially when introducing a power adder. But, for anything under 100hp of nitrous introduction, the factory fuel pump will be fine if it is indeed working in perfect order. I would suggest checking the injectors and at least have them professionally cleaned (none of this add to the gas B.S.). But with a wet setup the nozzle induces fuel as well as nitrous to equate for the more oxygen the nitrous offers.
Yep, I'm right. I know.:frog:
91 hatch Si
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 09:23 AM
86 celica turbo 4 sale celica 86 turbo Classifieds 0 04-16-2009 03:42 AM
Ford Probe 1992 2,2 turbo ptq Probe 0 04-13-2009 04:30 PM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 05:25 PM
Turbo CTR? Ricochet Forced Induction 15 09-13-2003 02:58 PM
